#3 High Cyl Temp/Wierd Engine Problem???
Old May 26, 2009 | 03:57 PM
Strelspeed's Avatar
Default #3 High Cyl Temp/Wierd Engine Problem???
Hi,
I hope someone can help. I have been around Honda's for over 15 years now and have come across a wierd problem with my 97 GSR.
The #3 cylinder reads about 150-200 degress hotter than any of the other three cylinders, even at idle. I get the temp by using a infrared thermometer on the header.
The car blew a bone stock GSR motor @ 125k, and I am the second owner since 88k. No mods, all stock, and the original owner just ran it as a commuter. Wierd or what?
It is an OBD2 car. I have swapped inj between cyls, and even repinned #3 & #4 at the ECU and ran the inj plug from 3 on 4, and the high temp continues.
The old motor had a ton of carbon on the inside of #3 and burned an exh valve.
Any ideas?
I did try an OBD1 computer, and no difference...
HELP before this nice low mile H-motors JDM motor pops too!
greencivic_0789
May 24, 2011 01:22 AM
Strelspeed
May 27, 2009 07:08 AM
Strelspeed
May 26, 2009 09:27 PM
mexicanstud
Aug 20, 2007 06:52 PM
RoofusX
Aug 23, 2001 06:31 PM
