torque specs
Old May 26, 2009 | 02:47 PM
teggything's Avatar
Default torque specs
i need a few specs i have a helms but im thinking its wrong it says main cap bolts to 7ft/lbs. any way i need the crank(or main) cap bolt specs(LS), arp rod bolt specs(LS), and Golden Eagle(GSR) head stud specs. i am doing an ls-v build please
Old May 26, 2009 | 02:59 PM
champLSinteg's Avatar
Default Re: torque specs
Off the top of my head...
Main caps - 56ft/lbs
Arp rod bolts - 28ft/lbs
Head studs - I go with 75ft/lbs on them
Old May 26, 2009 | 03:47 PM
teggything's Avatar
kinda want a for sure answer lol dont want them too loose or tight ecspeciallythe rotating assembly
Old May 26, 2009 | 07:22 PM
teggything's Avatar
ttt please help i would like to torque them down
Old May 26, 2009 | 09:48 PM
RA429's Avatar
for sure...
arp rod bolts = 26 ft/lbs
arp head studs = 80 ft/lbs or 85 ft/lbs with 40w oil
should be the same for the GE studs
Old May 27, 2009 | 08:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
All you need to know about LS/VTEC build-ups, including torque specs
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Old May 27, 2009 | 09:50 AM
teggything's Avatar
56 ft/lbs thx
crxkid24
Dec 1, 2006 10:02 AM
the.hamburglar
Feb 17, 2006 06:48 AM
The Jacko
Aug 12, 2005 08:29 AM
dumpeDc2
Oct 29, 2004 01:43 PM
