Extended Wheel Studs
I got a 97 Integra LS and im looking to get Extended Wheel Studs. There are two different sizes. One is 12x1.5 and other is 12x1.25. What are the differences? And which one should i get that will fit my 97 LS Integra?
for the rears, you should be able to just remove the brake disc rotor and just knock the old ones out and put the new ones in..
the fronts might be a little harder to get the old ones out since there is not enough clearance (hub blocks the studs from coming all the way out)..
Erics 96 NSX T
Mar 17, 2011 04:34 PM
Tokyo_X-treme_Racer
Jul 20, 2004 08:10 AM
