Suspension & Brakes Theory, alignment, spring rates....
Left suspension clunking -searched!
Old May 26, 2009 | 11:15 AM
JSiRTO's Avatar
Default Left suspension clunking -searched!
Car: 2000 EM1. Lowered on Neuspeed Race, stock shocks, which are on the way out, but not leaking.
PROBLEM: So, my suspension is clunking on the driver's side. When i raise the car and even remove the wheel I can not replicate the noise. When the car is stationary and on the ground, and I just jiggle the steering wheel from left to right slightly, I hear a light clunking. Driving is not stable, the car seem so sway at highspeeds or if there are 3-4 people in car while braking. Also, I can feel the movement under the floorboard near the pedals.
So far, this is what i've done to try and diagnose the problem.
-Checked lower ball joints
-Tie Rods
-Upper Control Arm/ball joint
and these all checked out okay.
-Had a mechanic look at the bushings to tell me they were fine
I do have some play in the sway bar endlink, but can this be associated with the problem?
I pulled at the axel and it just has the normal amount of play (left-right)
Anyways, some insight would be greatly appreciated. TIA.
Old May 26, 2009 | 05:44 PM
alscrx's Avatar
Default Re: Left suspension clunking -searched!
Grab the front sway bar and shake it. Usually the endlinks go bad.
Old May 27, 2009 | 07:51 PM
xd69's Avatar
I have Em1 front suspension on my hatch. I noticed a clunking noise appearing from one day to another. I took my suspension apart looking for the culprit thinking it was the balljoint on the UCA. Then my friend noticed that the endlink looked weird. Sure enough, one of the balljoints on the endlinks had popped out!! New endlinks now and problem free
BiG ChOr!Zo
52
Sep 1, 2011 08:42 PM
Si-Samuri
27
Dec 8, 2007 09:52 AM
ZexyAccord
Apr 15, 2005 04:35 PM
dnatrance
Sep 7, 2004 12:20 PM
Spade
Jun 20, 2002 07:43 AM
