Noise at at start up
Old May 26, 2009 | 05:14 AM
Tesla220's Avatar
Default Noise at at start up
Good Day All
I am new to this B18C GSR engine in my CRX... sometimes when I start it after it has been sitting for a day it sounds like possible rod or lifter noise for the first maybe 1/4 to 1/2 second at most. It could be normal for all I know, Ive never owned one. It could be I'm using the larger of the two oil filters although I thought they were interchangeable at least that far back (94), possible oil prime loosing it?
Anyone experience this?
My 327 did this crap for 6 years and never spun a bearing or kicked a rod and I am hoping that this is sometimes normal too....
Thanks!
Old May 26, 2009 | 09:25 AM
mouab18c1's Avatar
Default Re: Noise at at start up
i think its normal. it takes a few seconds for oil to run through the motor.
Old May 26, 2009 | 09:27 AM
mrdeadman's Avatar
They let me pick
What weight oil are you using?
Old May 26, 2009 | 11:03 AM
Tesla220's Avatar
10W-30
Seems to run OK, got lotsa goose with it now
Old May 26, 2009 | 11:47 AM
Ruben19's Avatar
is normal my d16 does the same. possibly low oil pressure when starting
Old Nov 27, 2009 | 07:04 AM
Tesla220's Avatar
Just a follow up.
The Cold Idle valve UNDER the throttle body has a pintle and seat in it, the seat had backed out causing very high RPM at start. The engine diddent have enough time to build oil pressure before whipping to 2500. I screwed the seat back in and this rattle is gone, also gone is the low speed hesitation when hot and now idles at 750 hot.
Kahl23
Honda Civic (2006 - 2015)
May 16, 2012 08:57 AM
roycivic92
11
Oct 9, 2009 06:16 PM
tegturbo
Jun 15, 2005 04:13 AM
Rah Rah
Dec 30, 2003 06:24 PM
firstgenrex
15
Sep 28, 2003 05:12 PM
