turbo oil lines?
Old May 25, 2009 | 08:24 PM
1992db2's Avatar
Default turbo oil lines?
so im building my car, and im trying to find the best and easiest way to feed oil to my turbo. Will a blox sandwich plate work?
Old May 25, 2009 | 08:30 PM
k24em2's Avatar
Default Re: turbo oil lines?
yea
Old May 25, 2009 | 09:51 PM
1992db2's Avatar
ok, thanks.
anybody else have any opinions? questions?
Old May 26, 2009 | 12:14 AM
EJ8 944's Avatar
I suggest using a sandwich plate as well, some people prefer to run T's off the back of the block.
Sandwich plates just seem less of a hassle to me, and it makes a cleaner install.
Old May 26, 2009 | 10:22 AM
1992db2's Avatar
so blox sandwich plate it is. anybody got any other suggeestions?
Old May 26, 2009 | 10:36 AM
dpetro1's Avatar
sandwich plate will work or t off the oil sender, there are many people who make kits for it.
https://honda-tech.com/forums/forced-induction-49/build-your-own-turbo-oil-line-kit-starting-%24-39-shipped-1902396/
https://honda-tech.com/forums/forced-induction-49/turbo-oil-feed-return-kits-oil-restrictors-2239281/
http://www.stealthmodeperformance.com/oil-kit.shtml
Old May 26, 2009 | 10:20 PM
1992db2's Avatar
i have the fittings to t off the oil sender, they were the ones in the first link, the first one on their posts.
should i use those instead of using the sandwich plate?
Old May 27, 2009 | 04:28 AM
dpetro1's Avatar
it really doesnt matter either way. skipping the sandwich adapter will save you like 40 bucks
Old May 27, 2009 | 08:53 AM
jdm inc's Avatar
you can feed your oil line either way seen it done both ways and they work just fine.
Old May 27, 2009 | 10:10 AM
EARLdaSQUIRREL's Avatar
official honda whore
sandwich plate works great as long as it seals to the block and doesnt leak oil out from there
Old May 27, 2009 | 10:18 AM
0611den's Avatar
maybe both,for oil feed,oil pressure gauge,oil temp gauge.
Ls_dx's Avatar
I run a straight -4 braided line and remote mount it to my firewall. then I use a female 1/8 tee, put the stock dummy light in one side and run another -4 braided line to the turbo. ive never messed with any sandwich plates.
Old May 27, 2009 | 10:31 PM
1992db2's Avatar
picked up a blox sandwich plate today guys. im going to give that a try.
Vryantec
Jul 13, 2018 03:12 AM
kebroz
Aug 7, 2017 06:40 PM
1997boostedeg
Apr 10, 2012 06:58 AM
wade
Oct 10, 2004 07:38 PM
gigantor
Feb 11, 2003 08:06 AM
