considering doing a full suspension overhaul - 98 civic 4 door
Old May 25, 2009 | 07:42 PM
nycdave's Avatar
Default considering doing a full suspension overhaul - 98 civic 4 door
I've got a 98 4 door with H&R springs and tokico blues. the car rides okay but even though I've also got a shitty ebay camber kit the tires are wearing horribly in the rear and the front isnt too much better. my question is this.... I would like to have fully adjustable arms and whatnot as well as strut tie bars to tighten the car up as much as i can. What would you guys recommend I replace? pix would be awesome too if you can help me out with that. My motor is stock so I dont know that I can do a strut bar up sicne the intake is in the way.
thanks
Old May 25, 2009 | 08:09 PM
batallic's Avatar
Default Re: considering doing a full suspension overhaul - 98 civic 4 door
did u get an alignment, since toe does more damage to tires than camber
Old May 25, 2009 | 08:20 PM
nycdave's Avatar
yes but not for a while. The camber is still way off in the rear. the tires angle inward at the top.
one other question - anyone ever have the issue with one side of the car sitting slightly higher than the other side? I noticed this with the driver side sitting lower than the passenger side.
Old May 26, 2009 | 08:22 PM
nycdave's Avatar
ttt
Old May 26, 2009 | 08:40 PM
IP RACING's Avatar
yea my car seems to sit a bit lower on my driverrs side. Im going to assume its from the extra weight on that side since people use their cars solo a lot more than with people in it.
Old May 27, 2009 | 02:28 AM
nycdave's Avatar
Guys any help on this would be great. What arms and/or bars would I need on this job? pix would be great too. thanks so much
Old May 27, 2009 | 06:23 PM
nycdave's Avatar
t
Old May 27, 2009 | 06:40 PM
alphalanos's Avatar
You dont need anything. Get a 4 wheel alignment. He already told you its toe that wears tires much more than camber. Some negative camber helps with cornering grip. I run -2 degrees in front and -1 in back with toe set at 0 and perfect tire wear. strut bars are not necessary to have a good handling car. If you dont already I recommend getting a rear sway bar and subframe brace. A great setup is the ASR brace and 22mm ITR sway bar. Can be bought as a kit at many online stores.
Old May 28, 2009 | 06:38 PM
nycdave's Avatar
thanks for the info. what shocks and struts do you have then? and you do have a camber kit correct? anyone else help? thx
Old May 31, 2009 | 10:06 AM
nycdave's Avatar
ttt
tonyhatchetman
17
May 21, 2010 10:22 PM
craiger28
16
Apr 4, 2010 12:37 PM
slumzo
Dec 5, 2009 08:43 PM
lazy bum shaughn
18
Feb 2, 2003 02:44 PM
99DXcoupe
Sep 27, 2002 09:35 PM
