b18b engine problems after doing swap.
Old May 25, 2009 | 06:44 PM
vadimqwe's Avatar
Default b18b engine problems after doing swap.
I did b18b1 swap in my ej1 and first week it worked great. When summer came I started to have problems starting the engine after driving it. The engine will crank but will not start when hot. I replaced main relay and checked my grounds. Also tried pumping fuel many times before cranking. it looks like im not getting sparks when my engine is hot. when it cools it will start.Please help me solve this.
thanks
Old May 25, 2009 | 06:55 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: b18b engine problems after doing swap.
check your plugs and plug wires. get new ones. if you have generic plug wires that cannot conduct alot of heat then...they are ****. get real ngk wires.
Old May 25, 2009 | 06:58 PM
vadimqwe's Avatar
they are oem and I think oem is proven to work cuz honda wouldnt make them if they would cause problems...
thanks for help
ChrisVTEC
Jun 18, 2015 05:37 AM
j4s0n1337
41
Feb 19, 2011 07:50 PM
HondaDream
Mar 12, 2009 10:26 AM
Cashieboi
Jan 1, 2007 03:44 PM
jdmCivic925
Oct 22, 2005 03:12 PM
