rack and pinion
Old May 25, 2009 | 03:57 AM
JDM_Certified's Avatar
Default rack and pinion
I Tried Doin A Search, And I Replaced A Few R/p But None On A Cb7, I Took Out All The Mounting Bolts And The P/s Lines On The Rack And Pinion And Nothings Holding On To It Except The Steering Knuckle...and I Tried To Wiggle It Out And Move It, pry it out, and Everythign And That Sucker Won't Come Out, I Can Spin It 360 Deg. And Still won't Come Out...is There Any Way I Can Take This Out..i Need It Asap Cause I Have So Much Play..thanx Alot..
Old May 26, 2009 | 08:30 PM
Default Re: rack and pinion
c'mon! alot of honda owners out here! help me out man!!!! anywaies!
Okay, so I've read and followed the DIY and I know i did exactly what I was told to do. Yet, I still can't happen to get it out even though its already lose. Does anyone on here know how to get this part off? It's still stuck on the little rubber that is on the chassis.
Old May 26, 2009 | 10:11 PM
CD5_530's Avatar
did you go under the dash & remove the 10mm screw where the steering wheel shaft meets the rack & pinion?
Old May 27, 2009 | 04:21 AM
yeah i just did, but now im tryna wiggle it out of the rear crossmember! this thing is a bitch!
Old Jun 9, 2011 | 08:16 PM
project_cb7's Avatar
did you loosen the rear subframe bolts a little to help give you a littler more room to work with.
Luckywhiteboi
Feb 28, 2009 10:24 PM
SLeePeR-STaTuS
Aug 6, 2007 11:49 PM
GSRcivicGSR
Mar 10, 2004 05:01 PM
Diablo Tejano
Feb 11, 2003 02:02 PM
LB CRX
Nov 18, 2002 12:30 AM
