burning oil bad
Old May 24, 2009 | 02:50 PM
lilshady6796's Avatar
Default burning oil bad
okay well i changed my rings because they were bad but i still burn oil really bad and my car boggs with real bad power loss and when i come to a stop it wants to stall most the time it does can some one please help me with this i need the car for the week...
Old May 24, 2009 | 03:08 PM
TravisCadello's Avatar
Default Re: burning oil bad
do a compression test. maybe you installed the rings wrong and your loosing compression. that or the timing is off.
and maybe ur rings weren't the problem of why it was burning oil. maybe your valve guide seals are bad.
Old May 24, 2009 | 03:09 PM
98civdx's Avatar
Master Detailer
how many quarts is it burning?
were the rings installed properly? are the valve seals gone?
is it leaking anything?
Old May 24, 2009 | 04:07 PM
well oil comes out the tail pipe, no i am not leaking other then that, and the rings are installed correctly...i am sure its the valve seals...btw valve seals and seat they are the same right????
G3teg96
Aug 20, 2011 05:00 PM
IgnitionZ05
Apr 12, 2007 11:20 AM
EF'n Sedan
Mar 15, 2006 08:37 AM
xlusiveracer
Sep 7, 2005 04:13 PM
someday
Nov 4, 2003 07:12 PM
