SKunk2 exhaust set up issue
Old May 24, 2009 | 01:11 PM
Jimmyhf51's Avatar
Default SKunk2 exhaust set up issue
ok my situation is that i installed my Skunk2 Megapower R(70mm) piping with my test pipe and my hytech replica headers and i have been driving it for a few days and good god its is soooooooo loud!!! im talking about i turn my system up in the car and its still loud.
So i was thinking if i can use my itr axleback and get a 70mm flange and weld it and bolt it on to the skunk2 piping?
will it become alot quieter or wat are the pros and cons of this situation any advice would be great thanks
Old May 24, 2009 | 01:21 PM
VietSpeed's Avatar
Default Re: SKunk2 exhaust set up issue
If it was me I'd just put the silencer in. but most likely you can just bolt the axleback on from your ITR to the Skunk2. Not really any pros to doing that but it will get quieter. And cons, I think will be the restricted air flow you just now put on the exhaust. Or even better yet invest in a Magnaflow Carsound High Flow Cat, you'll probably be more satisfied than replacing the axleback.
Old May 24, 2009 | 03:07 PM
wegotmorrison's Avatar
I have Skunk2 and its pretty loud, but not too loud that it sounds bad, or bothers me too much. My friend has Skunk2 with a test pipe and its WAYY too loud IMO, thats ur problem
Old May 24, 2009 | 11:28 PM
Jimmyhf51's Avatar
yea same here my cars loud becuz the test pipe and that my cars is fully built as well too so it just adds to loudness but the itr axleback wont bolt up cuz its not the right size flange.
so wegotmorrison wat did u end up doing with ur exhasut to get it quieter or did u just leave it?
Old May 25, 2009 | 06:54 AM
sean2000gt's Avatar
i have a skunk2 60mm exhaust on my gsr and it's pretty loud. deleted the cat so it's just the skunk2 resonator and muffler. it gets very annoying with how loud the drone is driving around. for ***** and giggles the other day i bolted on my stock muffler and oh my it was sooooo quiet. sounded totally stock again. but it killed the torque so i put the farter back on.
Old May 25, 2009 | 12:42 PM
mrdeadman's Avatar
They let me pick
Put the cat back on and it will quiet it down.
Old May 25, 2009 | 05:04 PM
I just left it. It gave me decent power, and It sounds really good at high RPM's. Its not a ricey sound at all with just the Skunk2 cat back. Like I said, pretty loud, but still sounds good.
Old May 27, 2009 | 11:08 PM
Jimmyhf51's Avatar
yea i ended up getting used to the sound even tho its pretty loud but i put the silencer on there and it reduces the sound by quite alot but it makes me lose crazy power but i guess i can put the silencer on when i go on dates and it will be fine.
another question is does any one have an issue with how low the exhasut or the resonnators sits after installing? cuz its seriosuly sits like 2in or less on the ground. the sresoncator like scrapes everywhere i go especially on driveways.
Old May 27, 2009 | 11:09 PM
Jimmyhf51's Avatar
any guesses on dyno numbers with this exhasut/header/test pipe setup?
Old Jun 5, 2010 | 01:30 PM
ninty1civic's Avatar
This 70mm exhaust wouldnt bolt up to the stock cat, its way too big for an 97 ls..
Im wondering if a different year or gsr cat would bolt up to it?
If not, it sounds like i need a highflow or a testpipe..
What should i do?
Old Jun 7, 2010 | 07:56 AM
bump for my answer..
Old Jun 7, 2010 | 09:35 AM
mountainbiking's Avatar
your going to have to get an aftermarket high flow cat in order to get the sound that you are looking for. The test pipe is what is causing the issues. Bolting up an axle back exhaust is going to hurt your performance one way or another.
Drewk909
Nov 24, 2014 02:46 PM
98cfprelude
Apr 9, 2012 06:46 PM
damonk
Sep 19, 2004 06:20 PM
LiL DeViL
Apr 24, 2004 05:41 AM
