GSR discs and calipers on civic hub
Old May 24, 2009 | 12:55 PM
boost and bass's Avatar
Default GSR discs and calipers on civic hub
I never heard this before but i was told that on 96-00 civics you can put gsr discs and calipers directly on the spindle without having to swap it for the gsr one. Anyone heard this or know if it is true?
Old May 24, 2009 | 02:27 PM
alphalanos's Avatar
Default Re: GSR discs and calipers on civic hub
Depends on model. If you have EX/Si you can. IF you have lower model:
to 94-01 Integra
Take the EX/Si knuckle (with bearing and hub) and bolt on the 17CL14VN 94-01 Integra calipers, caliper mounting brackets, rotors, and pads and swap them onto the Civic DX.
Old May 24, 2009 | 03:59 PM
98civdx's Avatar
Master Detailer
yep ex.si will work not sure about lx.dx
Old May 24, 2009 | 04:01 PM
JDM_SOHC's Avatar
time and money wise its gonna be equally the same to just find a junked teg and remove the assembly to swap it on..
Old May 24, 2009 | 05:48 PM
Vindicator9000's Avatar
318 Curves, 11 miles
You're talking about fronts, right? Maybe I'm wrong, but I didn't think you could directly swap integra disc stuff to 96-00 EX rears. If so, I'm hittin the junkyard tomorrow. Otherwise, yes, you can swap GSR stuff to Civic EX fronts as described by alphalanos.
On the rears, scarebird used to make a mounting bracket for about $100 that would allow you to bolt rear gsr calipers to EX drum spindles. Other than that, I don't think so.
Old May 25, 2009 | 07:14 AM
well i have a dx the back is already swapped, civic integra and crx are all the same, but i think i have a civic trailing arm, but i was told i can simply place the integra disc and caliper on my hub and bolt the caliper onto my knuckle but, i always knew u had to change the hub and knuckle, im just checkin i wanna do a front swap and that would make things alot easier
95_GSR_SEDAN
17
Dec 9, 2009 04:25 PM
Igarut5410
Suspension & Brakes
Oct 26, 2008 03:06 PM
97civic94gsxr
Aug 1, 2008 07:57 AM
revhigh96
44
Jun 21, 2004 11:22 AM
hybrid901
Feb 13, 2003 01:12 PM
