Help with CEL codes/ troubleshooting
Old May 24, 2009 | 08:03 AM
MrMug3n's Avatar
Post Help with CEL codes/ troubleshooting
I have a 93 delsol SI with a jdm B16a. also a jdm p30 ecu.
1) Problem is my car was stolen and the ****** cut the ecu out so now i have a wiring mess. im throwing codes 3, 7, 14, and 20. everything looks good machanicly all sensors are ok.
03: MAP - manifold absolute pressure sensor
07: TPS - throttle position sensor
14: IAC (EACV) - idle air control valve
20: Electrical load detector
2)as far as rewiring the ECU the...
A25(power source) and B1(power ground) are both yellow with black stripe and when i run continuity thru either one of them, every yellow and black striped wire in my car F'n beeps.
So how can i tell what my problems are?
Old May 24, 2009 | 08:35 AM
MrMug3n's Avatar
Default Re: Help with CEL codes/ troubleshooting
Problem solved! i had the TPS ground (Green w/White stripe) switched with the IVAC (Blue w/ yellow stripe) harness by the ECU had Green and white for both
cksnah252
Oct 25, 2017 12:45 PM
Markb16a
11
Jan 22, 2013 09:19 AM
SsSteven
Mar 15, 2010 05:36 PM
fishy21
Feb 1, 2010 11:00 AM
do_0b
Apr 2, 2008 03:19 PM
