squeal on startup
Old May 24, 2009 | 07:08 AM
supermeister's Avatar
Default squeal on startup
hey, i have a d15b and most of the time when i start it up it squeals. sometimes it is just a quick burst and others it lasts a couple of seconds. it also happens when i rev the engine sometimes. i dont have ac or ps so i ruled out that it could be a belt issue. what could this be?? any help is greatly appreciated! thank you!
Old May 24, 2009 | 07:11 AM
92eg_h22's Avatar
Default Re: squeal on startup
alternator belt or the pulley on the alternator.....definately a belt issue
Old May 24, 2009 | 11:03 AM
Juan_Mitosis's Avatar
Yup
in order:
1. Check belt tension
2. Use belt conditioner
3. Replace belts
Old May 25, 2009 | 01:41 PM
i tightened the belts and the belts looked fresh so i dont think they need replacement. i don't have any belt conditioner but i think it might be fine. ill see in the morning
Old May 25, 2009 | 02:27 PM
Former User's Avatar
Remove the A/C and PS belts (permanently) to see if the noise goes away.
If the noise persists, then also remove the alternator belt (temporarily).
Old May 25, 2009 | 03:09 PM
The_Honda_Guy's Avatar
It's most likely the belts but an easy way to check quick is to spray a small amount of belt dressing onto them and see if the noise goes away. If it does, then replace the belts. Otherwise you can just do it like Ron said and remove the belts one at a time.
EGed up from the seat up
May 25, 2010 03:45 PM
integra15
Sep 13, 2008 01:34 PM
VTECth1s
Aug 30, 2006 10:24 PM
dizzogotvtec
May 13, 2006 01:49 PM
stRodda
Sep 12, 2003 04:42 PM
