crv front suspension problem
hi, i have a 98 crv. i have a problem with my front camber at the driver side it is off +1.06 degrees or it is leaning inside, anyone who can help me with this, thanks.
i already have an alignment. i got the result of that from wheelworks. looking for more info regarding my problem. they said the solution is to compensate at the upper lca to use an adjustable ball joint. but im looking for more dept info about this...
its all stock... i think none is replaced since i bought it (used)...
hmmmm i think i have a +1.06 degrees or the whell is slightly tilted inwards if your looking in the front of the suv... and what do you recommended for lower ball joint removal and installation tool? i've like do change it my self if thats one of the problem.
