need help with b16 swap
Old May 23, 2009 | 10:30 PM
Eletcrik_600RR's Avatar
Icon2 need help with b16 swap
so i bought a 90 integra ls with a b16 swap for very cheap, but it had some driveability issues. i don't know how you can mess this swap up this badly but he did. most concerns have been repaired, but it still has major wiring problems. first, the only sensors that change anything when unplugged are the ones on the intake manifold. it has 3 coolant temp sensors?? no knock sensor, and only one o2. it gets 10 mpg(running very rich), runs like a bag of ****, and no check engine light. check engine only comes on when the map, tps, or iat are unplugged. it is not an ls or a b16 harness and there's a lot of half *** wierd wire splice's and wire routing going on. does any one have a 90 91 ls harness or have any advice on how i can easily and cheaply fix this. i called around and went to 20 diff junk yards and was unable to find one for a 5 speed.
Old May 23, 2009 | 10:45 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: need help with b16 swap
Find out what ecu is being used, also iv never done a swap but i believe you can use the 93 gsr harness or you might be able to use one from a 94 del sol they came with the b16a, but im not sure gl.
Old May 24, 2009 | 10:15 AM
pr3 b16a ecu
Old May 24, 2009 | 03:06 PM
Revolemilbus's Avatar
Sounds like you definitely need to rewire the thing, I did a OBD-0 B16A in my civic hatch. I used my 1989 Civic Si harness and it had every single thing I needed minus Vtec (oil pressure switch, Vtec solenoid, Secondary O2, etc.) so I wired that myself, thats the cheapest way to go. What I recommend is going to www.rywire.com they make plug and play harnesses for all your honda needs.
Old May 24, 2009 | 04:15 PM
4teg0029's Avatar
From: birthplace of "Battle of the Imports" palmdale, CA
that's why you always should be concerned when you buy a car that was modified by the previous owner......even if you get it for a great deal....you might end up spending alot of money on it to fix it or just to get it running the way you want...
as for your question....get a helms manual and go over and over all the electrical as much as you can.....electrical issues are the hardest to fix imo, cuz everything can be right but one little thing can screw it all up!!
GL!
Old May 24, 2009 | 10:01 PM
thanks, other than the ls harness what other common harness can i use? obd0 milky white/ clear connectors
Vspronk
Nov 3, 2015 09:49 PM
Brettw
Apr 29, 2013 04:47 PM
ltzracer
Nov 17, 2006 06:09 AM
onefastx
Oct 25, 2006 04:09 AM
PYITR821
May 30, 2004 09:38 AM
