i can't find the PCV on a 92 GSR
Old May 23, 2009 | 07:35 PM
ahhshietitztony's Avatar
Default i can't find the PCV on a 92 GSR
i just bought a 92 GSR couple days ago. when i went to get it smog check, it failed and in the description, its says "PCV Modified" but i try looking for it but don't know where it is located. and also, can someone tell me how could i correct the problem so i can pass smog.
thanks
Old May 23, 2009 | 07:41 PM
kingcu90's Avatar
Default Re: i can't find the PCV on a 92 GSR
HEY HAVE U TRIED LOOKING UP ON GOOGLE UNDER IMAGE.... THEY SHOULD HAVE WERE IT GOES IF NOT GET A CRICKED SMOG CHECK..........LOL..... HOPE THIS HELPED ....................................BUMP.......... .................
Old May 23, 2009 | 07:45 PM
tried looking google for images, but doesn't really help.. and i have a bit of an idle problem, which i think might be cause but the pcv
Old May 23, 2009 | 09:26 PM
MikendablkDB8's Avatar
it is usually on the intake manifod or under it
Old May 23, 2009 | 10:28 PM
stevenDAtegra's Avatar
You know the black box on the backside of the block that is for crankcase ventilation?
A hose will go from that to the PCV and a hose from the other end to your intake manifold. It should be mounted somewhere on your intake manifold, probably in the middle and right where the manifold bolts up
Old May 23, 2009 | 10:37 PM
^^ that too
Old May 23, 2009 | 10:49 PM
wunfstgsr's Avatar
Loved
Community Favorite
Its located right on top of the black box on the back the block, it will most likely have a red top and its a L shaped plug in valve, its routed to the top of the intake manifold by a vacume hose someone correct me if im wrong.
Old May 24, 2009 | 07:03 AM
ropeadope14's Avatar
New User
its pretty big u shouldnt miss it
Old May 24, 2009 | 07:11 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
thanks
Is the breather hose hooked up from the valve cover to the intake tube? If not it would probably fail inspection like how you stated.
Notmyusername
41
Nov 12, 2020 12:59 PM
crispchris
Oct 22, 2014 03:08 PM
Touch
10
Oct 20, 2006 04:23 PM
jay_cue
17
Dec 9, 2005 06:18 AM
