WTT/TW:95 GSR JDM FRONT,JDM B18C
Ok im trying to see if there is any interest in my 95 dc2. I've had the car less than 3 months.. i bought it as a shell real junky with cut wires and whack *** interior..
MOTOR:
JDM SIR-g 95 spec motor about 70-75 k mileage
Skunk 2 pro intake manifold'
JDM ITR throttle body
Blox TPS sensor
NEW vtec solenoid gaskets both of em
Y21 b16 tranny
chipped PO6 ECU
JDM ITR THROTTLE BRACKET AND CABLE
WATERPUMP(BRAND NEW UNINSTALLED)
TIMING BELT(BRAND NEW UNINSTALLED)
CAM SEALS (BRAND NEW )
SUSPENSION:
stock shocks cut springs
x drilled slotted rotors
EXTErior:
JDM FRONT( MISSING LIP)
99 Rear bumper
99 spec taillights
98-01 type R doors
interior was replaced with tan interior from old owner...... im trying to swap it all out back for some gsr peices.. I also gotten Brand new Front hardlines and lines to MC. 95 integra RS master cylinder and brake booster. i bought fresh driver side wire harness. Clean ABS delete
IM TRYING to trade for 89-95 240 SX depending on year will depend on if i add cash or str8 trade.. if its an s13 you must have sr20 swapped.. also willing to trade for fc rx7, 99 si .. picks will be posted soon car is alot of colors no dents at all fresh professional body work dont.. doors are type r white like the rear bumper front end is blackish metallic and chassis is black with white primer.. Rad support t bar is just bolted in place will need to get it welded when you get it painted..
MOTOR:
Blox TPS sensor
Y21 b16 tranny
chipped PO6 ECU
SUSPENSION:
EXTErior:
99 Rear bumper
99 spec taillights
98-01 type R doors
TheCrookedH
Aug 7, 2007 05:07 AM
