Car died
Old May 23, 2009 | 04:55 PM
civic_driver's Avatar
Default Car died
Hey,
I was driving down the street and the car suddenly died. The dash lights went off and the motor died. The radio kept working though. I thought it might be the alternator but the radio was working while the dash lights and the motor died. What do you think caused this? Could it be the ignition switch?
I turned off the car with the key and then when I turned it on everything lighted up again and the car started right up.
This is a 99 Civic DX-V.
Old May 23, 2009 | 05:14 PM
Pothole987's Avatar
Default Re: Car died
I would say that has to be a bad ignition
Old May 24, 2009 | 05:34 AM
Anyone else with more ideas?
Old May 24, 2009 | 06:38 AM
Former User's Avatar
I would also guess a faulty ignition switch.
Old May 24, 2009 | 08:25 AM
Yeah, I was thinking it might be the ignition switch; the weird thing is that the radio continued working while the dash lights went off. It's weird because if it was the ignition switch, the radio should've stopped working as well, right?
Old May 24, 2009 | 11:37 PM
r1lsr's Avatar
my rsx has the same problem, the on switch wasn't working for some reason. Dealer couldn't find the problem, so I replaced the switch and problem went away for about a few weeks, then it happened again. So, I'm thinking you got a power surge that is buring out your switches somewhere. I heard on the Acura TL's, they got a massive recall on the ignition switch. So, I'm just guessing Honda has been making bad switches.
Old May 25, 2009 | 07:01 AM
I think I had a similar problem when I had my first 95 Civic long time ago and the ignition switch was the problem. Just can't remember if my radio kept working or everything was out when it happened.
Old May 25, 2009 | 02:23 PM
I just searched and found a recall on the ignition switch on this particular car. I guess I will have it replaced under the recall and see if the car still stalls.
Old May 27, 2009 | 04:35 PM
r1lsr's Avatar
yeah, my rsx is still crappin out on me, it is really frequent when my turning signals are on. It even dies when the car isn't started. I would leave it on the on position with the wipers, turn signals, lights, etc. on and it would die for maybe 5 minutes then power back up. Do you guys think it could be the fuse box?
Old May 27, 2009 | 05:17 PM
It's possible. Sounds like an intermittent connection, most likely one of the main cables (power/ground). It could also be a problem with the ignition switch itself--a loose wire somewhere.
Old May 29, 2009 | 12:24 AM
r1lsr's Avatar
I'm gonna go through and recheck and reconnect every single wire this weekend. I'll let you guys know what happens because just recently my girls dad's friend came and looked at and said that the stereo was hooked up wrong. So he rewired that and said that the car is fine now, but I still don't believe it because the stereo cannot burn out the signals or ignition switch, can it?
Old May 31, 2009 | 07:50 PM
r1lsr's Avatar
The car hasn't died since, I don't know who hooked up the stereo because I am the 3rd owner, but whoever they are needs to quit wiring stereos.
Old May 31, 2009 | 08:27 PM
Good to hear it's fixed now
treal512
Feb 20, 2015 06:50 PM
teg-rhonda
Oct 24, 2012 02:12 PM
Steve LeB
Sep 2, 2012 10:15 AM
r1lsr
Jun 1, 2009 11:37 PM
