TRAILING ARM BUSHING ISSUE NEED HELP
Old May 23, 2009 | 01:34 PM
Akavietboy201's Avatar
Icon7 TRAILING ARM BUSHING ISSUE NEED HELP
Wat sup hondatech i have problem wit my Trailing arm is the rubber bushing is busted. But now i dont know wat should i replace the bushing OEM or AFTERMARKET 1 here is the my option can u help me pik it out
1) Oem bushing from ebay $60
2) Energy bushing $44
3) Prothane bushing $60
4) Oem from dealer $103
5) Hardrace trailing bushing $85
Old May 23, 2009 | 01:38 PM
racebum's Avatar
Default Re: TRAILING ARM BUSHING ISSUE NEED HELP
any or all. harder rubber isn't a bad idea really. hardrace probably makes something like that. the only issue with poly is that it wears since you have a pivot inside. i've had ES bushings in my trailing arms for 2yrs now with no deflection but it's really a personal choice call. the prothane stuff is way overpriced though. honda/es/hardrace....i'd be happy with any of the 3 myself. you'll probably be hearing from a few people who are dead set one way or the other. how many of them have tried all 3, probably very few.
Old May 23, 2009 | 02:04 PM
Tarmac Junkie's Avatar
Hardrace...
Old May 23, 2009 | 03:17 PM
thank you all what if i can buy Prothane bushing for $ 60 buck is dat good deal or wat lmk hondatech
Old May 23, 2009 | 03:18 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Go to www.slhondaparts.com
Type in this part number: 52385-S21-003
Order 2 OEM trailing arm bushings at $29.71 each.
This fits 94-01 Integras. Does not fit 90-93 Integras.
Old May 24, 2009 | 08:43 AM
can i get more option here about the bushing lmk wat is good hondatech
Old May 24, 2009 | 09:32 AM
If you want something more high end, performance wise.
http://www.hondamarketplace.com/show...g+arm+bushings
Old May 24, 2009 | 01:29 PM
Community Builder
DO NOT use spherical if the car is anything other than mostly track-driven. They will wear out in a relatively short amount of time if used on public roads in all weather conditions. I really don't see any point whatsoever to have zero suspension compliance on public roads.
Old May 26, 2009 | 01:12 AM
So Patrick u mean i should go wit the OEM bushing right don't go with the Prothane bushing. The Integra is daily driving some time aim going to the tracking
Old May 26, 2009 | 02:10 AM
racebum's Avatar
bearings are a bad idea on the street because of contamination. ES or hardrace would be my choice. oem are alright, just if you want rubber, you have hardrace which deflects less.
Old May 26, 2009 | 02:40 AM
DA9_DAD's Avatar
I have the black (If you buy the red, you will need to attach a Zerk fitting to keep them from squealing, The black have impregnated graphite to automatically keep the bushings lubed) ES bushings on my DA...I've also installed them on my EF sedan. Never a problem. The pin is free to rotate when you lower your car....something you need to consider if you want to put the OE/OEM bushings.
And it also depends on what your trying to achieve. If your just streeting the car, with an occasional 2nd/3rd gear pull with friend, etc etc then go with the above.
If your going to track the car...then just like the others said...use the spherical.
Hard race probably just applied a sticker and a mark up in price.
I have a write up on how to install them posted in the FAQ's.
Old May 26, 2009 | 08:49 AM
rebar71's Avatar
If this car is your DD, then stick with OEM bushings.
Old May 27, 2009 | 01:09 AM
My choice right now is either Prothane bushing or hardrace bushing. Cause the Prothane bushing i can get it for $60 brand new, But i don't know Prothane bushing it is hit hard on rock on the pot hole or not ??? I want something smooth ride but good tracking though.
Old May 27, 2009 | 06:58 AM
jason256's Avatar
You could try the hardrace sphericals. They have dust boots to prevent contamination and a layer of rubber that's supposed to make them not too bad for street use. I just bought a set but haven't put them on yet. I'll let you know how they ride once I do.
Old Nov 21, 2009 | 10:48 AM
tlchkc's Avatar
I just order some Hard Race. I'll let you guys know how they ride and feel.
Surdomute56
Mar 30, 2017 09:30 PM
BlackCivicEX
Suspension & Brakes
29
Jan 24, 2012 10:27 AM
PatrickGSR94
Suspension & Brakes
14
Dec 4, 2008 06:08 AM
beav
Suspension & Brakes
21
Dec 19, 2006 06:00 PM
bigBOI_92DA9
Sep 12, 2005 11:28 PM
