DA disk brakes on ef's?
Old May 23, 2009 | 08:06 AM
alx_90ef's Avatar
Default DA disk brakes on ef's?
OK so i heard you can put the DA rear trailing arms and the DA front disk and caliper.
does anyone have like a write up on these?
or some pictures?
it'll be much appreciated.
thanks
Old May 23, 2009 | 08:58 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Default Re: DA disk brakes on ef's?
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
Old May 23, 2009 | 10:35 AM
Deetz's Avatar
Crazy Honda Guy
I did it, and regretted it
- spent money on the swap parts
- gained weight
- no performance gain
Now, i ask myself why i wasted my money
Old May 23, 2009 | 10:47 AM
redflaredcrx90's Avatar
pyes you can do it you need da front hubs rotas calipers . for the rear you need rear trailing arms calipers rotas an ef si brake cables da will work but i think there a lil long. theres not much to write up its a matter of pulling your off and putting the new ones on if done right better stoping oh you need a 4040 poporsion valve from a 90-91 si or a da90-93 integra
Old May 23, 2009 | 10:53 AM
Deetz's Avatar
Crazy Honda Guy
Meh, when the CRX got rear disk in 90-91, it actually had longer stopping distances than the older model with rear drums. There are many track test to prove.
It's true, that in many instances, rear disk would be considered an upgrade, but not in the case of the CRX or DA set up
Old May 23, 2009 | 06:52 PM
alx_90ef's Avatar
wow thanx
Old May 23, 2009 | 11:27 PM
jpciii's Avatar
90-91's are heavier so longer stopping distances would be expected. Drums work great, but rear disks look way cooler than a dinky drum back there.
Old May 24, 2009 | 06:32 AM
i have a 90 si and i dont have any issues with stopin if fact mine emproved it i have das on the front and stock si on the rear the front has a big brake 13 in the rear is has slotted rotors i also have ksport coil over and energy suspetion bushing too
Old May 24, 2009 | 06:52 AM
dj-t's Avatar
Someone told me that when you brake the front does 75% and the rear does 25% of the braking so shouldn't you focus more on the front brakes if you want more stopping power.
I am also debating if I should get a rear disk cause I like the look of rear disk on the EF or use the money to upgrade my fronts.
92hondaswap
Nov 29, 2008 05:18 PM
funkfnamna
Sep 9, 2008 07:01 PM
whole9
Apr 28, 2006 05:58 PM
SilverDc2
Sep 10, 2003 04:37 PM
brian.edge
14
Dec 6, 2001 06:26 AM
