Catback System Fitment for 2/4dr GSR
comparing the full catback system underneat the car for the 2dr and 4dr
what are the length / fitment difference?
also... does some1 have pictures of how it look underneath throughout the
catback system?
best picture is by the cat converter with the heat shield / header section.
thank you in advance.
catback system?
all the midle sections are the same, only difference is pre mid-pipe, after cat length, that varies from vtec and non-vtec headers...some catbacks have a longer axleback section on the sedans as well..most cheaper companies make it longer anyway, to fit both
someone correct me if i got it wrong
94-97 GSR's are different from everything else. Otherwise, the only different between 2dr and 4dr is the length of the tailpipe (which is longer on 4dr). No diff. between vtec and non-vtec, other than what i mentioned.
Search to verify. This has been covered before.
