battery dies while riding.
Old May 23, 2009 | 04:15 AM
swappedcx's Avatar
Default battery dies while riding.
Well i bought a 600rr track bike and of course the previous owner messed with all the wiring. he eliminated the tail light, kick stand, all bar mounted switches and the ignition. Well I had to install a kickstand and wire that up, a tail light and rear brake switch, headlights and a left headlight/blinker switch. I got everything to work on RUN (obv, since no key). My problem is I can have the battery at 12.6v not running. When I start the bike and have my DVOM hooked up it will drop to 11.2v then go up and hover around 13.3-13.8v depending on the rpm. I had the low beam hooked up on and the bike at idle testing this, then turned the highs on and it stayed the same no matter how i varied the rpm. Well then yesterday I took it for its first ride. I smelled oil burning, like it was dripping on the bike so I pulled over on top of a hill (on purpose) to check if oil was leaking, which it was not and when I went to start the battery was totally dead. I had to pop start it down the hill, now why is my battery dying while running if at idle its sitting at 13.3-13.8ish with high beams on?
Old May 23, 2009 | 04:18 AM
swappedcx's Avatar
Default Re: battery dies while riding.
the battery is a year old, but it is good still. I had to start the bike so many times before to check little things here and there and the battery will start the bike 20ish times no issue. It seems its apparently when its running and I imagine the lights are on. I just unplugged the headlights so Im going to charge it up and take it for another run in a while and see if it charges or kills the battery again.
Old May 23, 2009 | 06:11 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
i would say its the the rr, but if its staying at a constant 13.8 volts while its running then it leads me to believe the battery is bad.
Old May 23, 2009 | 06:19 AM
EngineNoO9's Avatar
Should be higher then 13.8v when charging, more like 14.5v. If the battery is old get a new one and try that. If you still have issues check into the Regulator/Rectifier
Old May 25, 2009 | 08:10 AM
TeamZigen's Avatar
Your stator is bad and eventually your battery. Pull out your stator, probably the coils are burnt.
nveley22
Honda Motorcycles
Sep 15, 2013 05:47 PM
the_gambler
Honda Motorcycles
May 15, 2009 06:05 AM
crxma22
Honda Motorcycles
Jan 16, 2009 09:50 AM
lowRIDAH
Honda Motorcycles
Jun 26, 2007 01:00 PM
Matt Groove
Honda Motorcycles
Apr 11, 2005 06:08 AM
