Driver Side Window Problem
ok so, this just happended today, when i roll the window down it makes a little pop then a loud one, then when i roll it back up it pops a little tiny bit and vibrates a little too, what could that be? and how do i go about fixing it?
dont roll it up or down anymore until you take off the panel and fix whats wrong. most likely a screw or nut came off and something is fighting it. if you keep trying like i did, a rod and other plastic stuff snaps and the window falls in
ohhh, alright, yeah i took the panel off and tryed sprayin wd-40 on the track and nuts and still didn't help, but i wont roll it up or down anymore until someone can tell me exactly whats wrong. thanks for the help though
What year/make/model?
And look on the metal door panel for loose bolts/nuts. I had quite a few in mine. But it did have almost 300k on it. Something may have worked loose, and now the track isn't in place.
I put them back with some loctite
00ekcoupe
13
Aug 27, 2005 10:52 AM
