NA injector upgrade?
Sounds fairly decent. Dont forget to get a better fuel pump and a FPR. A stock pump might be able to handle it but if your going to put a bigger motor in later you might as well get the cheap insurance now.
I'm planning on building either a d16z6 or y8, but I'm not sure witch pistons to go with. I will be using these injectors in the 1.6 when its completed regardless...was just checking to see if they would work in the 1.5 as well.
Most stock D-series injectors (including the D15B7) are 240cc. Some (maybe all) of the '96-'00 D16Y7 injectors are the ones that are 190cc. Hell, even the '92-'95 CX, with all it's 70hp glory, comes with 240cc injectors. And the D15B7 is the engine from the USDM '92-'95 DX & LX, and it is a non-vtec engine.
where did you get this injector info? i did the math(on the RC web site)to determine what size injectors i would need. the numbers came to 210cc, so i landed on the 240's for saleability...
another question: what pistons are best for a NA vtec 1.6 z6 or y8 with crower rods?
http://www.turbod16.com/viewtopic.php?f=7&t=19966
http://hondaswap.com/general-tech-ar...-flow-rates-6/
http://www.clubcivic.com/board/showthread.php?t=71064
If the H-T search engine didn't suck so bad, I would have been able to easily find more examples of from this site. A google search will produce even more.
vartok
Feb 16, 2013 08:58 PM
SOHC_2_DOHC
Mar 19, 2008 06:39 PM
