IN: FS/WTT DB1 Integra Turbo
PLEASE BUMP IF YOU VIEW, THANKS!
The GSR blades are already sold!
Engine
OEM head gasket
JE pistons 10.1 at 81mm
Eagle rods ( the new ones with the big rod bolts)
ACL Standard size bearing
Rage engineering blockguard
Head-stock
obd0 stock b16 throttle body
AEBS mani
750cc sat rcs
AEM rail
sx fuel press reg.
-6an return line
AEM power steering pulley
greddy catchcan (modified to breather type)
prelude block fitting for catch can
deleted PCV system
ES tourqe mount inserts
battery relocation to the trunk
Tuned on chrome
Running 20w-50
Transmission
93 LS tranny
ACT stage 3 clutch
Running synchromesh
Ignition
MSD 6al (located in glovebox)
blaster ss coil
Brand new msd cap/rotor
Moroso wires
ngk 7es
Turbo Setup
t3/t4 drag gen turbo .63 ar
Manifold tapped for egt
3" custom downpipe with flex
3" custom mandrel bent exhaust with magnaflow muffler
2 o2 bungs (after tune you can just plug the bungs if needed)
Custom intake with vaccum source if needed
KN filter
HKS 40mm wastegate
HKS SS blow off valve
All custom IC piping
T-bolt clamps
Turbonetics couplers
Spearco 350hp intercooler
Greddy spec 1 EBC with remote switch
Cooling
Full Race Half Size Radiator (Almost new, ran for less than 300 miles)
12" slimfan
Interior
Stock seats
Auto cluster
Momo 360mm wheels
momo hub
F-1 concept button
Defi D-gauges(discontinued) a/f,boost,EGT,fuel pressure
Autometer phantom- oil pressure
Suspension/Brakes
H&R race springs
tokico blues
all ES bushings
drilled slotted rotors
stainless brake lines
Blow extended wheels studs
New wheel bearings
All new pads and rotors
blox extended studs
Exterior
Vigor Wing
"Type-R" front lip
Bumper shroud cut out for intercooler
JDM headlights
MIGHT COME WITH SALE
Work Equip 01 Wheels (15x7.5 +35 offset)
Almost new HP Fuzion tires (Less than 300 miles on them)
Bad:
The fuel pressure gauge isn't working. It tics between two different readings consistently.
There is a slight curb on one of the wheels. It's about one inch long, and is only on the lip of the wheel. I'll post detailed photos soon.
Paint is peeling of of the spoiler very badly.
Those are old photos from a different owner. (I hope he doesn't mind me stealing them..) The valve cover has been replaced with an OEM black one. The radiator has been replaced with a half size radiator and the respective hoses. No more ugly metal couplers between hoses-
Asking $5500 without the wheels. Will increase the price with the works, but I'd rather not sell them. I am VERY open for trades. I'm really looking for an AE86 hatchback, but I will consider other cars, too.
I'm located in southern indiana.
PM for my telephone number/more information-
Engine
OEM head gasket
Head-stock
AEBS mani
750cc sat rcs
AEM rail
sx fuel press reg.
-6an return line
deleted PCV system
Tuned on chrome
Running 20w-50
Transmission
93 LS tranny
ACT stage 3 clutch
Running synchromesh
Ignition
blaster ss coil
Moroso wires
ngk 7es
Turbo Setup
KN filter
HKS 40mm wastegate
T-bolt clamps
Cooling
12" slimfan
Interior
Stock seats
Auto cluster
Momo 360mm wheels
momo hub
F-1 concept button
Suspension/Brakes
H&R race springs
tokico blues
all ES bushings
New wheel bearings
blox extended studs
Exterior
Vigor Wing
"Type-R" front lip
JDM headlights
Bad:
Last edited by tree fingers; May 24, 2009 at 10:33 AM. Reason: adding more pictures
yea i msgd you in zilvia. Trying to get rid of this http://chicago.craigslist.org/nwc/cto/1193356052.html so I can buy your car. I miss my old db1 http://www.youtube.com/watch?v=loL8reSqkMM
It's still for sale. : ]
812-459-5469
w00t w00t
Nov 21, 2004 10:03 AM
