loose front end
ok, first things first..my upper ball joints need replacement. secondly, when i grab ahold of either front wheel and move from side to side, shes a little loose. i did some searching and i'm wondering if this is my problem(rack and pinion). a few of my friends were under the vehicle when she was on the lift and i was moving each wheel, and that's where the clunking came from, the steering rack. if so do i need to replace the entire component?
tie rods are good for sure, I ordered new and took everything apart assuming it was them. Tie rods were great. like i said, everything seemed to come from that rack.. are there bearings inside to replace or what?
i read somewhere where they said that if the rack and pinion is bad you can tell when you first start the car up and even though you have power steering it his hard to turn the wheel either side and then go back to normal like mine...!!!
j0keefe21
Feb 5, 2009 04:25 PM
schueytenten
Nov 20, 2008 02:19 PM
