Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Help!!!EVAP Bypass Valve for Pilot
Old May 21, 2009 | 04:28 PM
AnDThEnWuT's Avatar
Default Help!!!EVAP Bypass Valve for Pilot
Help I need a part number for my 03 Pilot. I have a check engine code P1457 and I'm trying to fix it myself, problem is I'm not sure which part is considered the bypass valve. Is it the Two-way valve? I already tried calling my local honda dealer and he has no idea what I'm talking about. Any help would be appreciated. I'm trying to avoid getting raped by the dealership with parts and labor.
Old May 21, 2009 | 04:58 PM
qwrty's Avatar
Default Re: Help!!!EVAP Bypass Valve for Pilot
in my invoice it says: canister vent shut valve
will it be the same as for crv???
i happen to ask for that solenoid this morning in the dealership...
17310-sv4-L32 $147.44
i have a gen.1 99crv ex, it did throw me that code once..
i think its also caused by the gas cap too tight and not tight,
i havent had a CEL eversince im the one closing my gas tank..
the gastender (gas attendant) might fill it up to the brim too!
HTH..
Old May 21, 2009 | 05:16 PM
qwrty's Avatar
hope this link could help:
http://www.in.honda.com/Rjanisis/pubs/SB/A03-001.PDF
good luck!
Old May 22, 2009 | 08:49 AM
TODAwhore's Avatar
http://slhondaparts.com/search.asp?p...ch+Database%21
its located near the gas tank
Old May 23, 2009 | 03:58 PM
92civlude's Avatar
You want to replace both the 2way and the bypass solenoid. They both get contaminated at the same time and they are bolted to each other. They are located near the canister. Solenoid- 17012-S10-L01. 2way- 17371-S0X-A02. Good luck!
Old May 23, 2009 | 04:35 PM
AnDThEnWuT's Avatar
Thanks for the replies! This really helps narrow it down. I'll change both parts just in case. I'll let you guys know how it turns out.
MarvKirsch
12
Mar 8, 2020 12:25 PM
integra_type-r
Oct 14, 2007 09:03 PM
b18c-1
Sep 25, 2006 02:05 PM
Linh.
Dec 10, 2005 10:03 AM
mtfishin
Nov 8, 2004 06:35 AM
