any dd boosted f22 accords ?
Old May 21, 2009 | 09:55 AM
keoni96764's Avatar
Default any dd boosted f22 accords ?
whats your setup? pics? hp? thanks
Old May 21, 2009 | 10:06 AM
UK Accord's Avatar
Default Re: any dd boosted f22 accords ?
Here's the Spec & pics of my DD Accord:
Make: Honda
Model: EDM Accord 2.2i Vtec sohc
Year: 1998
Engine Management: P28 ECU mapped with Ectune
Engine: F22 Z2
Chassis: CE9
Mileage: 82,500
Weight: 1270kg
Power: 12.5 psi 300bhp @5560rpm & 301lb ft Torque@4910rpm.
Engine:
Wiseco 8.8:1 Forged Pistons (85.5mm)
CAT Power Super H Beam Forged Rods
ARP Headstuds
Turbonetics T3/T4 Turbo V trim stage 2 .48 51 Lbs/min
Turbonetics Evolution wastegate
Turbonetics Raptor BOV
Custom 2.5 inch Downpipe
Treadstone coated cast manifold
Treadstone TR8 intercooler
Treadstone 2.5" I/C pipes
Treadstone complete oil kit
HRC Racing 255lph Uprated Fuel Pump
440cc Lucas Injectors
HRC Racing Fuel Pressure Regulator
AEM Tru Boost Contoller
Apexi Power Intake
Exedy Stage 2, 3 Puck Cerametallic Clutch
Fidanza Aluminium 8lb Flywheel
Prospeed Custom 3inch Decatted S/S Exhaust with 4.5in Tailpipe
Odyssey PC680 Battery
Mocal Oil Catch Tank
Air Con Removed.
Old May 22, 2009 | 09:30 AM
keoni96764's Avatar
how much was your head studs?
Old May 22, 2009 | 09:35 AM
twkdCD595's Avatar
H23 ARP head studs are about 130.xx-140.xx for a set when I bought mine.
I would add mine to this but its not daily driven.
Old May 22, 2009 | 10:24 PM
keoni96764's Avatar
Make: Honda
Year: 1998
Engine: F22 Z2
Chassis: CE9
Mileage: 82,500
Weight: 1270kg
Engine:
ARP Headstuds
Apexi Power Intake
Air Con Removed.
nice do you have any vids? i really want to see what a 300 hp accord can do i want to make a stage on my dual boost controller for that. if you dont have any vids can you make some. thanks for the replys later
Old Jun 14, 2010 | 02:13 PM
Turbomax's Avatar
i have bought this car now and looks like this now
i have put stickers on since this and rear lights have been done with couple of other bits also few engine bay mods.
cheers max
Old Jun 14, 2010 | 03:50 PM
TheShodan's Avatar
Moderator
I loved those European accords for years.
Old Jun 14, 2010 | 04:01 PM
redflaredcrx90's Avatar
wow post some more
Old Jun 15, 2010 | 04:30 AM
Turbomax's Avatar
thank you. the white is pearl so with the pirate black it changes in the sun,alloys redone in pearl as well. i will get some more pics up soon. cheers max
Old Aug 20, 2010 | 10:45 PM
Turbomax's Avatar
car has been off the road with a blown headgasket. while this has been done the car has been overhauled by frost motor sport. its had a new 6 puc clutch fitted ,lsd gearbox,new lightweight moly flywheel,head been skimmed ,new valve guides,seals,regrind and lapping,aem pulley, honda mls gasket used, honda gaskets inlet/outlet.
the car will be ready ASAP and once bedded in will back on the rollers to check everything is ok. next step is the injectors and remap which should take her to 375bhp.
cheers max
UK Accord
Nov 6, 2007 06:55 AM
Excelerate
Jun 24, 2006 10:10 AM
Excelerate
Jun 23, 2006 06:27 PM
rhdune16
May 13, 2005 10:50 PM
rhdune16
May 6, 2005 11:10 AM
