NEED HELP
Old May 21, 2009 | 09:42 AM
madgeo's Avatar
Default NEED HELP
I have a 90 HF that i'm going to be doin a B18b1 swap into. the problem that i'm having is, i don't know what clutch to go with? I will be putting a turbo in a year later after the motor. Local guys around here said to go with a 6 puck clutch.I heard of clutchmaster,ACT...Is F1 any good also??? Any help on this matter would help. Thanks in advance
Old May 21, 2009 | 09:54 AM
0ne-Cam's Avatar
Default Re: NEED HELP
I wouldnt recommend that 6 puck if its going to be a daily driven car.
Old May 21, 2009 | 09:55 AM
madgeo's Avatar
to add the 6 puck in after i turbo then?
Old May 21, 2009 | 09:59 AM
0ne-Cam's Avatar
Yeah when you start the build, but if you install it now it will be a rough ride. But it all depends, is it a heavy duty unsprung or sprung disk?
Old May 21, 2009 | 10:00 AM
madgeo's Avatar
i really don't know. i just need to figure it out before the swap
Old May 21, 2009 | 10:11 AM
Bunger's Avatar
A sprung hub 6-puck isn't too bad for a daily driver really. And I've daily driven a 3-puck with an extreme pressure plate... was pretty much like a switch, great fun to watch the guys at americas tire try to move the car into a bay... lol!
Old May 21, 2009 | 10:15 AM
0ne-Cam's Avatar
I seen people say good things about the sprung 6puck clutch and when shifting its not so rough. But I suggest getting a stock one
95jeremie
Nov 30, 2007 11:32 AM
vxturbociv
May 4, 2006 03:03 PM
baruba
Sep 24, 2003 12:11 AM
ahobbs
Aug 12, 2003 12:29 PM
wannabe psi
Aug 4, 2002 06:14 PM
