dohc cams stuck, wont rotake with engine
Old May 21, 2009 | 09:39 AM
thegatekeeper14's Avatar
Default dohc cams stuck, wont rotake with engine
okay so i built a 20, vtec and intalled everything but now when i try to rotate the engine the cams dont rotate and the belt slips... cam cams are lubed with oil and not on very tight, anyone have any ideas?
oh and when i disconect the belt from the cams. the engine turns fine.
Old May 21, 2009 | 09:54 AM
jdm inc's Avatar
Default Re: dohc cams stuck, wont rotake with engine
which cam? Intake or exhaust?
Old May 21, 2009 | 10:00 AM
dyingwish's Avatar
Did you remember to put the woodruff keys back in place when you put the cam gears on?
Old May 21, 2009 | 12:12 PM
Intake cam
Old May 21, 2009 | 01:25 PM
averyvm's Avatar
hmm thats wierd. If I were you I would miticulously double check everything. And you should try rotating the cams by hand before putting the belt on. This is something that you should carefully such that you have no piston to valve contact
Old May 21, 2009 | 01:54 PM
delsolproblems's Avatar
Try removing the distributor.
Old May 21, 2009 | 02:02 PM
h22 civic's Avatar
PISTON 2 VALVE
Old May 21, 2009 | 02:47 PM
1SLOW93TURBO's Avatar
I'm new and not sure of your knowledge but are you rotating the motor the correct way. The wrong way will cause the belt to slip?
Old May 21, 2009 | 06:07 PM
fcm's Avatar
fcm
Old Fart
Originally Posted by h22 civic
PISTON 2 VALVE
X2.94
Old May 21, 2009 | 06:24 PM
jdm inc's Avatar
take your distributor out and see if it will turn.
Old May 24, 2009 | 09:25 AM
boosted.da's Avatar
first i would start from zero and dial everything into zero
Old May 24, 2009 | 11:27 AM
blaze the chemi's Avatar
Make sure you didn't over tighten the cam caps and then also make sure the spark plugs aren't installed. The spark plugs keep pressure inside the cylinder and it's much harder to turn the motor over that way.
Old May 24, 2009 | 12:06 PM
tofast4uh22's Avatar
it is obvious that this person does not know how to assemble a engine. i.e. "when i turn the motor over the cams dont move and the belt slips" well if the belt slipped enought the piston would hit the valve, bending it and locking the top end of the motor up. check your valves and replace them cause there toast. gl.
PURPLERANGER
Sep 9, 2014 12:19 AM
asbloodrunsblak
Oct 27, 2009 07:16 AM
vttitan18
Jun 5, 2008 05:22 AM
cRxAuDio
Sep 10, 2003 01:18 AM
B18C
Jul 30, 2003 03:30 PM
