Where is 91 accord's auxiliary fuse situated?
Hi everyone. I know for many of you this is problem is simple to fix,but not for me.
My prob is I've checked the signal switch of my accord,viewing from wire side,probing 7-9 for Right 8-9 for Left.the ohm meter moves. So i think the switch it's ok.
The problem started with a faulty speed sensor,then it lit up my MIL light. then the MiL went off after 100 miles.together with it,
The signals,temperature,rpm,speedometer,dash clock,door warning light.
Except the hazard,headlights,instrument lights, fuel gauge and the battery warning lights that are still working.
but today after i checked around the connectors,the fuel gauge needle when erected till it passed the full mark.
the only thing that i didn't check is the auxiliary fuse.because i don't know where it is situated. i looked at the service manual and the under dash fuse box looks the same as my accord but my auxiliary fuse is no where to be seen. I hope somebody can help me locate it.
Its a 1991 Honda accord cb3,sm4 EXI 2.0 without cata or cruise control.
Thanks everyone.
Thanks everyone.
jjenks
Feb 23, 2010 08:03 AM
svselva
Sep 29, 2005 07:37 PM
jweller
Oct 28, 2003 04:54 AM
