h2b bogging..help...
i recently just tune my car a 1 week or so. just today i gunn it a couple of time and it bog out on me (anywhere from 2800rpm to 3500) after that it will drive or if doesnt pick up between those rpm when i step on gas i would hear my intake suck in air but it doesnt go anywhere..mph would just drop..i would have to take it out of gear put in a lower gear and punch on it than it will pick..
i checked, battery +/- make sure its tight,all sensor, vacum line/ ground wires, ngk plugs make sure both ways are tight. even replace spark plug.
the car feels like it want to go but something is holding it back..
the car crank up fine/idel where is suppose to be
plz help.....i'm lost....
check your map sensor...i have the same set up and my hood was hitting my map sensor
i went tru 3 map sensors then i got tired and moved my map to the firewall wit a bracket and ran a vac. line to it from the manifold
deff check your map
deff check your map
88crxdxfastwhip
Jan 24, 2006 01:52 PM
