Broken CV Boot - Please help!
Old Aug 18, 2002 | 09:42 PM
dynamo's Avatar
Default Broken CV Boot - Please help!
I start changing the oil on her 1994 Accord Ex this weekend, and as I loosen the drainplug I see that the inside of the driver side wheel is completely covered in grease. The boot is snapped in half. Fortunately, no clicking or any other sounds from the wheel, so I assume the bearing and hub are still okay.
I will be getting the CV Boot replacement kit from the dealer tomorrow. Could someone please give me some pointers, or if possible a step by step on how to get this fixed? She just lost her job, and I need to get it done this week since she has to start going to interviews and look for work.
Thanks in advance for the help!
Old Aug 18, 2002 | 09:46 PM
2000Accord5sp's Avatar
Default Re: Broken CV Boot - Please help! (dynamo)
I might be wrong but I believe it's a lot easier to just change the whole CV joint. You can pick them up at any junk yard for pretty cheap (refurbished ones) and that way all you do is take out the bad CV joint and replace it with the new one (instead of taking out the bad one, fixing it and putting it back in). Seems easier/quicker to just do it that way.
Old Aug 18, 2002 | 09:47 PM
David B's Avatar
New User
You can buy a new (rebuilt) axle shaft for $75 Lots of times once the boot is broken they get contaminated . Plus it is not worth the trouble just swap it out . Thats my 2c good luck
Old Aug 18, 2002 | 09:52 PM
dynamo's Avatar
Default Re: Broken CV Boot - Please help! (David B)
Sweet - I'll make calls about it tomorrow.
Any pointers/instructions on how to replace the axle? Her car is an Automatic, if that makes any difference.
Old Aug 18, 2002 | 10:02 PM
David B's Avatar
New User
You gots any tools? Or a friend
you need a 36 mm Socket to breal the nut for the axle this will be the hardest part if you dont have an air compressor then you need some pliers ,14mm ,and a 17 mm sockets Oh yeah a 19 mm for the wheel it is a pretty easy job about a 2 rating . you will need a small prybar to pop the axle out
HTH
Old Aug 18, 2002 | 10:10 PM
dynamo's Avatar
I have the right tools, but unfortunately no air compressor. Would a breaker bar about 3' long work? That's what I used to take take the hub off the axle on my civic.
How do I disconnect the shaft from where it enters the tranny/engine? Also, what will I have to pry it out of - the tranny or the hub?
Old Aug 18, 2002 | 10:14 PM
David B's Avatar
New User
You can do it with out a compressor . Break loose the 36mm axle bolt before you jack up the car. The axle pops out of the tranny that is why you need a small pry bar or very big screwdriver. you might need to jump on the ratchet to break the nut loose or put a 2 ft extention (pipe) on the ratchet handle
Old Aug 18, 2002 | 10:29 PM
dynamo's Avatar
How do I pop it back in after it pops out? And how is it attached in there - i.e. what makes it "pop"?
Old Aug 18, 2002 | 10:35 PM
David B's Avatar
New User
There is a little retainerclip that is built into the axle that keeps it in the tranny.
that is why you have to pry to pop it out once you get it pryed out just a little it will slide right out . Then when you install the new axle you can usually just press hard to get it to pop into the tranny
Old Aug 18, 2002 | 10:55 PM
ColdAccord's Avatar
yeah I paid 40 bucks for my axle, with a 75 dollar core charge. have a bucket handy, you'll lose tranny fluid when you pull the axle. you have to pull the little bit of metal (like a cotter pin, same function) away on the hub before you try to loosen it, or else it will just rotate the whole assembly. haha the most annoying part was getting the damn swaybar bushings back into place. found out those need replacing too. bag, next week......
Old Aug 18, 2002 | 10:57 PM
Accord94DX's Avatar
Default Re: Broken CV Boot - Please help! (ColdAccord)
you dont have to disconnect the swaybar. Just the lower ball joint.
Old Aug 18, 2002 | 10:58 PM
dynamo's Avatar
Where is the cotter pin? On the hub? And, will I need to disconnect the steering arm to get it apart?
Old Aug 18, 2002 | 10:59 PM
dynamo's Avatar
Default Re: Broken CV Boot - Please help! (Accord94DX)
Is the cotter pin he's talking about the one on the balljoint? Will I have to pop the balljoint out too?
Accord94DX's Avatar
Yes and Yes.
Old Aug 18, 2002 | 11:00 PM
David B's Avatar
New User
Yeah I forgot that part you need to buy a $10 balljoint spliter from auto parts store. my bad
Old Aug 18, 2002 | 11:04 PM
Accord94DX's Avatar
or use a huge hammer and knock the **** outta the joint.
Old Aug 18, 2002 | 11:07 PM
David B's Avatar
New User
Yeah but if you mes up that bolt and mushroom it you cant get the 17mm nut back on. I have messed up a few that way . Not worth the chance if you ask me
Old Aug 18, 2002 | 11:17 PM
dynamo's Avatar
I think i'll play it safe and just rent the balljoint tool from Kragen. That's what I used to remove the balljoint on the civic.
Will I lose a significant amount of tranny fluid? Should I get some to drain and replace just in case?
THanks for the help guys, I will get started on this tomorrow. At least she doesn't have to go to work on it (yet) so I have a couple of days to get it done.
Old Aug 18, 2002 | 11:19 PM
Accord94DX's Avatar
Tranny fluid? Maybe a pint if you are quick, closer to a quart if j00 are slow. Have the new one right next to you and bang it in quick after the old one is ripped out.
Old Aug 19, 2002 | 08:37 AM
dynamo's Avatar
Forgot another question: where is the jack-up point on the front of the Accord? I need to raise the driver side high enough to put a jackstand under it. On a civic, there is a metal point on the bottom right under the engine, where I can put the jack and raise the whole front end, while leaving the side jack points empty so I can slide in jackstands. I looked under the Accord, and there wasn't anything like that. Any ideas?
Old Aug 19, 2002 | 08:40 AM
greensleeper's Avatar
use the front tow hook
Old Aug 19, 2002 | 08:41 AM
dynamo's Avatar
Default Re: Broken CV Boot - Please help! (greensleeper)
Thanks, I'll look under it tonight.
Old Aug 19, 2002 | 10:13 AM
dynamo's Avatar
Can you give me a little more direction on popping out the axle? What kind of pry bar do I need? And where would I have to 'grip' it, and what to pry it against? Never done it before, so I am a bit baffled.
Old Aug 19, 2002 | 10:51 AM
GimpyAccord's Avatar
Just need a nice thin edged prybar (I use a tile bar)... gently wedge it between the transaxel (or halfshaft/intermediate if on drivers side) and she pops right out! Just make sure that the snapring is still on the end of the old shaft... if not you gotta find it in there.
I never get any leakage on the driverside (not sure if this is normal.. only accord ive worked on), but the passenger will let tranny fluid go.
one tip i have is to get the axel back into the hub: lightly lube it and tap the 36mm lightly with a hammer. this gets the axel back through the hub easily for me and then out enough to thread on the axel nut. you really gotta crank this SOB down.. 157 ft. lbs if i remember right so have a good torque wrench!
after you're done ...
I rate this a job .. okay im a nerd.
[Modified by GimpyAccord, 7:52 PM 8/19/2002]
Old Aug 19, 2002 | 01:34 PM
dynamo's Avatar
Default Re: Broken CV Boot - Please help! (GimpyAccord)
Does it make any difference that the car is an Automatic, or does the axle pop out of the tranny the same way on Manual and Auto?
Also, I jsut got off the phone with Kragen, a refurbished axle is $80 as long as I bring in the old one for an exchange. Thanks for the tips guys!
aZnAcCoRd02
Feb 20, 2007 07:41 PM
mist sITR
Sep 25, 2003 11:02 PM
Doogie Howser
Sep 2, 2002 11:05 AM
pelotudo
Aug 11, 2002 05:26 AM
pelotudo
Aug 10, 2002 12:33 PM
