No Start
Old May 20, 2009 | 04:13 PM
blkngrn24's Avatar
Default No Start
Ok guys i have a 96 civic that about a week ago swapped a 99 civic si wiring harness, b16, and all the parts onto. I ran the car for the past week and had no issues at all till yesterday when i installed my sterio, i put the sterio in and out of nowhere the car would crank over but wouldnt start. I checked my fuses under the dash and replaced 3 that were blown and then my car started.
I drove the car around that day with no issues and then just randomly the car shut off and did the same thing, it would crank but no start so i checked all the fuses and they were good. I decided to double check all of my grounds and found that they are all still hooked up. I also rechecked the wiring and it doesnt look like anything has come disconnected. I also checked the ecu in another civic and the car started so thats still good and i replaced the coil and module from a d series distributor that i had laying around and know ran (yes they are exactly the same). I also replaced the main relay and checked the under dash fuses and all is well i just cant get it to start.
Any ideas?
Old May 20, 2009 | 04:44 PM
Former User's Avatar
Default Re: No Start
Do you have bright spark at all four plugs?
Do you hear the fuel pump prime for 2 seconds when the key is turned to ON(II)?
When the key is turned to ON(II), does the CEL remain ON steady?
What three fuse blew originally?
Luke67801
19
Jun 17, 2015 06:45 AM
LadyDelSol
Nov 7, 2010 06:31 AM
EFdood831
21
Aug 16, 2009 01:07 PM
boosted_lude
Jun 14, 2007 01:32 PM
KillerBee18
Jan 27, 2005 03:32 PM
