Check engine light started to blink and lost power
Old May 20, 2009 | 03:15 PM
B-money's Avatar
Default Check engine light started to blink and lost power
So last night I was coming home from work, my check engine light started to blink just as I was getting off on the exit. The engine started to flutter when I would come to a stop. It also felt a little weaker, but after the light started to blink I started to drive it real slow till I reached my house, less then a mile away from the exit. I checked the oil, and it looked fine. But I haven't checked my spark plugs yet. So if any of you guys recommend any mechanics around San Jose that I can take my car to, I would greatly appreciate it.
It has 115k miles, been burning a lot of oil lately, almost a quart a week. I check the oil on a weekly basis and add when necessary. Change the oil every 2500-3500 miles, and I don't drive it recklessly. I havent checked the spark plugs yet, but I changed them about three oil changes ago. Any advice would be great.
__________________
Old May 20, 2009 | 03:20 PM
quadracer's Avatar
New User
Default Re: Check engine light started to blink and lost power
u should check ure plugs, and then check the dizzy rotor...does it seem like its not getting gas?? mayb fuel filter clogged.. could b alot of things need little more info
Old May 20, 2009 | 06:14 PM
dk127's Avatar
So the CEL is not constantly on?
Old May 20, 2009 | 06:26 PM
Topshot's Avatar
A solid CEL is probably nothing too bad (probably the converter) but a blinking one is not good.
Old May 20, 2009 | 08:04 PM
forcefedferio's Avatar
^^^..or something like fuel system too lean/rich, sensor circuit/out of range problems. etc.. etc.. a check engine light isn't a "keep driving until the car shuts off one day, light." If your check engine light is flashing you have what is called a catalyst damaging misfire, your first step is check/replace all tune-up hardware including Plugs/Wires/Cap/Rotor/Fuel Filter as well as checking/replacing your air filter.
Old May 21, 2009 | 12:24 AM
EL TYPE R's Avatar
Icon6 Re: Check engine light started to blink and lost power
blinking check engine is a misfire.
check your plugs, rotor, cap, wires.
if its all good, compression test.
i had a hole in my valve.
tacchan
25
Apr 5, 2010 06:37 AM
LSxVQ35
Sep 10, 2008 05:31 AM
Berlinetta F1
Aug 16, 2007 07:02 PM
methods555
Jun 13, 2007 03:58 PM
shraz
13
Jun 8, 2006 08:11 PM
