Build b16a2 or Swap b20z?
Old May 20, 2009 | 02:25 PM
chaokongz's Avatar
Default Build b16a2 or Swap b20z?
Hey loooking for some advice.
I have a stock b16a2 in my eg and was thinking of a b20z bottom end swap or should i build the b16a2? And if you think i should build the b16a2 what build should i go? I plan on staying all motor.
I believe if i swapped it, it would run about $1800, would it be better results if i were to just build the b16a2?
One reason id like to swap is because the b16a2 i currently have in my car has no vin# for the motor and that kinda irritates me even though i talked to dmv and state police and they said it would be fine.
advice please? looking for best results possible!
Old May 20, 2009 | 03:01 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: Build b16a2 or Swap b20z?
Currently owning both engines, even a B20Z stock outperforms a B16A. I'd say go for the bigger motor, if you want to build it, even more power can be had
Old May 20, 2009 | 03:02 PM
98civdx's Avatar
Master Detailer
yep id go b20/vtec
make sure you do it right. tho, i would deffinetly go threw the block when you get it.
Synergy001
Oct 24, 2003 05:34 AM
