Honda S2000 Honda S2000
Back fire but no missfire cel
Old May 20, 2009 | 01:24 PM
Slammedsilverstone's Avatar
Default Back fire but no missfire cel
I am stumped every time I shift know matter what rpm I get a pop and a backfire. I know its not from having any exhaust issues because I have ran a strait pipe without this problem. I am concerned that it is a burnt or bent valve. I also have a periodical miss at idle but still no check engine light. I changed the plugs about 3k ago and they were NGK. The car runs great but has poor idle and this anoying backfire. I was told a bent valve will give you a check engine light and I would also asume it would give you drivability issues so idk. Anyone have problems with their injectors I have 110,000 on the car.... Thanks
Old May 22, 2009 | 05:40 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Back fire but no missfire cel
What do you plugs look like. This will tell us allot! Drive though a parking let in fist, shift and right after it backfires turn the car off, coast to a stop and pull the plugs. Report back with your findings.
You also need to give us some insight into your setup? 100% stock? AFC? test pipe? recent tune up? What plugs? factory computer?
CUTTERSPOOL
Jul 16, 2009 06:05 AM
shahram72
Dec 19, 2002 10:49 AM
