which silicone?
Old May 20, 2009 | 11:15 AM
FearTheH's Avatar
Default which silicone?
so i know what kind of silicone i like in *****... but what kind of silicone does my oil pan gasket thats being replaced like? thanks in advance
Old May 20, 2009 | 01:28 PM
FearTheH's Avatar
Default Re: which silicone?
anyone?
Old May 20, 2009 | 01:31 PM
Snafubmx234's Avatar
Any good hardware store or auto parts store should have something along the lines of "High temperature silicone sealant" that should work perfectly.
Old May 20, 2009 | 01:33 PM
BryanM.'s Avatar
Resident Gearhead
Honda Bond. Motorcycle/ATV shops usually have it on hand and usually cheaper than the Honda dealership parts counter. Got a tube last weekend for $17, dealerships generally charge about $22.
Ironically, I bought it for my B16A oil pan gasket.
Old May 20, 2009 | 01:39 PM
FearTheH's Avatar
honda bond is used to help adhesion between gasket pan and block from factory correct?
Old May 20, 2009 | 01:40 PM
That's what they use from the factory, but no reason to spend 4X the amount of money when high temp silicone will work.
Old May 20, 2009 | 01:49 PM
FearTheH's Avatar
yeah may go with the high temp stuff... just dont want to get some trashy stuff thats going to break up and get in my oil.
Old May 21, 2009 | 04:11 AM
The_Honda_Guy's Avatar
I would highly suggest using Hondabond HT. The problem with most other RTV's is that they will smear off or not stick properly. Usually when most other RTV's get oil on them they just goop off whereas Hondabond HT will stick and not run off. Also, Hondabond HT is what they used from the factory on the valve cover and oil pan gasket, so why not re-use what was on there to begin with?
Old May 21, 2009 | 05:28 AM
RyanA's Avatar
If you don't want to use HondaBond because of price or availability, I recommend you use Permatex Ultra Grey. It's the supposed equivalent to HondaBond. I have used it with great results (on friends cars that were too tight to buy HB....)
Old May 21, 2009 | 07:22 AM
nateb22's Avatar
supposed but not THE equivalent to it?
Old May 21, 2009 | 08:17 AM
CivicSpoon's Avatar
"Mitsubishi Engine & Transmission Silicone Gasket Sealant" is a damn fine silicone too.
Old May 21, 2009 | 11:25 AM
RyanA's Avatar
It's a little softer and runnier than hondabond when it comes out of the tube. They both set up fairly similar but the UltraGrey is a little softer when set up. They both work great.
Old May 21, 2009 | 12:10 PM
driveslow's Avatar
man I hated hunting down the answer to your same question. I ended up biting the bullet and buying honda bond at the dealer. it was 11 bucks for a 10-12 oz tube
Old May 21, 2009 | 12:12 PM
RyanA's Avatar
Pretty sure HondaBond only comes in the 1.9 ounce toothpaste tube. At least that's all I've ever gotten.
KooK
Jun 7, 2011 10:59 AM
black0hatch
May 11, 2009 03:09 PM
OldMrAccord
Jul 1, 2005 12:23 PM
CrX-To-Tha-Max-v2.0
Nov 16, 2004 11:38 PM
Boostless97Lude
Jan 31, 2003 08:33 AM
