88 hf crx rpm guage wont work
I finshed with my build but I cant get the RPM guage to work and since then I have installed 2 different dash harness and a different guage cluster from a 88 crx...but I cant get the RPM guage to work...i did go out and buy a little cheapo tach and I spliced it into the blue wire of the guage cluster and it works just fine but still no rpm's on my guage cluster. I could really use any and all help on this please!!!
Are you sure you have a working tachometer? It's possible that the gauge itself is not working.
You said you can get an aftermarket gauge to work, from the blue wire... so the signal should be getting to the factory tach, so either there is no power to the tach, a bad ground, or the tach itself is broken.
power...where does that come from(which fuse or power source)...also when I swap in my gsr cluster the tach works up until 5k then it bounces around
Yes it will! And as far as I can tell, all the ignitors are interchangeable, at least electronically... I've had to "modify" a few to get them to fit back into the distributor.
Ok so I changed the ignitor and the oem guage cluster now works but when you rev it to 5k or above the rpm guage goes crazy and just bounces around. I redid my ground for the battery but still no luck...anymore ideas now?
could it be noise from my supercharger?? i am running a b20 with a stepper pulley and a 3.0 nose pulley...other the the ignitor could it be anything else?
Some kind if electronic interference perhaps? The tach gets its signal from the ignitor, if that's breaking up, its either a bad connection, interference, or a ignitor going south.
of what the supercharger or the guage cluster?
Specs/Pics of my CRX
Ok I'm selling this to fund my new turbo S2000 project. I built the whole car...Motor and Chassis the motor and supercharger was installed and tuned by Secret Services and it made 186hp and 167tq at 9psi. I know I’m forgetting stuff so I will post it when I remember and I will include it in a few.
There is nothing wrong with this car (Motor and Suspension) but the interior and exterior needs a little work (dash,guage cluster,and driver window) the car has no ac but I have all the ac parts and also the Innovative mount ac bracket to reuse the stock d-series compressor.
http://viewmorepics.myspace.com/inde...lbumId=2189093
Motor and Tranny
JDM 99 B20 motor with a built head and a LHT JRSC with CTR tranny:
JRSC was sent to LHT and they installed an water intercooler inside and ported the manifold with a heat exchanger.
MVM Stepper Pulley and a smaller 3.0 nose pulley I will include the stock 3.2 nose pulley and alternator pulley
Cooling mist trunk mount Water/Meth injection kit.
RC 550cc injectors
AEM Fuel Rail
Aeromotive FPR
Walbro 255L fuel pump
Secret Services Stage 1 PnP
Crower Stage 2 Turbo Cams
Crower Dual Springs & TI Retainers
Snunk2 Cam Gears
Competition Clutch Stage 3 Clutch
Competition Clutch 8lb Flywheel
kamikaze header
Test Pipe
Tanabe Super Medallion Hyper Spec Catback
Innovative B-series mounts
Rywire obd0-obd1 sub harness
password jdm intake manifold gasket
Password JDM battery relocation kit with Odyssey PC 680 Battery & Brass Terminals
Chassis:
JIC RGTC N1 Dampers
Da Front and Rear Brakes
Front Suspension-
Brembro Drilled slotted and vented rotors with axis brake pads
Stainless Steel Edelbrock Brake Lines
Revo front camber kit
Suspension Technique 23mm sway bar
Innovative Front Cross member
Rear Suspension-
Brembro Drilled and Slotted rotors with axis brake pads
Function7 88 CRX Rear LCA's
Wicked Tuning rear caster camber kit
Wicked Tuning rear toe camber kit
Energy Suspension control arm bushings
Wheels and tires
16 inch Rota C10s, in black
BFG KDW's Fronts are 225/45/16 and rears are 205/45/16
I bought them from Silverbeast seen about 500 miles since I bought them.
http://www.houston-imports.com/forum...d.php?t=445628
The interior needs work.
Interior:
Corbeau Forza Seats Driver & Passenger (Black Microsuede)
Corbeau 4 point harnesses
Harness Bar
JDM Rear Seats uninstalled and in perfect condition
New carpet (never installed)
Civic dash with a 94-01 Integra center console (center console not installed)
Motor and Tranny
RC 550cc injectors
AEM Fuel Rail
Aeromotive FPR
Snunk2 Cam Gears
kamikaze header
Test Pipe
Chassis:
JIC RGTC N1 Dampers
Front Suspension-
Rear Suspension-
Wheels and tires
Interior:
Harness Bar
guys I still need some help with with...I tried 3 guage clusters and a standalone tach and 5 used ignitors from 5 known good dizzy's. This is a 99-00 b20 (obd2b i think). I wired up a el creapo tach and it works no problem. Also swapped out the rotor cap and coil. I have a obd 0 to obd1 ecu jumper harness and then the shop cut the dizzy plug off the b20's engine harness and spliced the dizzy plug onto crx engine harness
Anymore ideas? Also could someone point me in the direction for a wire diagram to convert my 88 hf crx to a 99-00 b20...just the dizzy part.
Is this right?? It's a quote from another forum.
Well you state that you have the obd0 to obd1 conversion harness who is that through? go to their website they will tell you in their instructions what wires are for what. But according to boomslang...
obd0 orange to obd2 dark blue
obd0 white to obd2 white
obd0 orange/blue to obd2 green
obd0 white/blue to obd2 red
obd0 blue/green to obd2 yellow
obd0 blue/yellow to obd2 black
obd0 large white to obd2 yellow/green
obd0 black/yellow to obd2 black/yellow
obd0 blue to obd2 blue
aznm1tch
Feb 24, 2013 07:42 PM
honda_boy23
Apr 14, 2009 08:47 PM
