Air Pressure for Spare Tire
Old May 20, 2009 | 08:20 AM
globy123's Avatar
Default Air Pressure for Spare Tire
Hi. I have a 99 Honda Civic Sedan.
I recently had a flat tire and when I changed it with the spare tire I noticed that the spare tire was low in air pressure.
What should the air pressure be in the spare tire?
Old May 20, 2009 | 08:22 AM
nateb22's Avatar
Default Re: Air Pressure for Spare Tire
read the side of the tire.
rick_rabies's Avatar
I'm not Rick!
40psi
Old May 20, 2009 | 08:35 AM
ekb16's Avatar
if its the small spare tire then it should be 60psi
Old May 20, 2009 | 08:52 AM
nateb22's Avatar
like i said, read the side of the tire
Old May 20, 2009 | 10:03 AM
globy123's Avatar
I looked at the side of the tire and it said 60 PSI. Why is the spare tire higher than the normal tires?
Old May 20, 2009 | 10:29 AM
r3v da t3g's Avatar
It takes 60psi because the size of the damn thing. . . . its a dinky little rim/tire. They designed the spare to fit comfortably in your trunk and be able to withstand the weight when you put it on the car. . . its like pretty much a trailer tire. Majority of dinky spares are 60. . . full size spares goes with whatever your manufacture says. . . if you are ever curious look on the side of your door. . . it will tell you what psi you should have on your front rear and spare tires.
Old May 20, 2009 | 11:38 AM
sde780's Avatar
I've always went by what's on the tire, not what's on the door jamb
Old May 20, 2009 | 11:45 AM
batallic's Avatar
side of the tire says 60 psi, on my 93 ex
Old May 20, 2009 | 12:50 PM
XKINGX's Avatar
the side of the tire dosent tell u what the factory calls for. the pressure on the side wall of the tire is the max the tire should ever see. i would guess 40psi but just a guess
Old May 20, 2009 | 05:02 PM
dew_fever's Avatar
FYI the information for proper tire PSI, check the inside of the door jam or on the vin on the door for OEM spec...driver's side front.
Old May 20, 2009 | 05:27 PM
nateb22's Avatar
why would you check the car for the tire pressure and not the tire?
they make the engraving on the tire for a reason.
Old May 20, 2009 | 05:30 PM
nateb22's Avatar
if the factory calls for something other than what the tire is, then why would they give you that tire?
Old May 20, 2009 | 05:53 PM
MonkeyMagic's Avatar
lol truf 60 psi
you never play a joke on somebody? nothin as funny as watching someone with a flat have another flat or a blowout
John 07
Mar 23, 2009 07:47 PM
.water
Apr 1, 2006 07:05 PM
tonezilla
Jan 26, 2006 08:52 AM
97dxnut
Apr 26, 2004 06:54 PM
PoonHunter
Jul 14, 2003 11:39 AM
