stereo install problem
Old May 20, 2009 | 05:23 AM
nauticalstar80's Avatar
New User
Default stereo install problem
im trying to hook up an aftermarket head unit for my del sol and i dont have power. i used a harness and all the colors match, i just cant get power into the radio. all the fuses are good. the battery was disconnected during install and when i plug the old radio back in the code light comes on so i know the old radio is getting power. does the anti theft have anything to do with it and if so how do i get aroud it. i need tunes please help.
Old May 20, 2009 | 05:28 AM
Eran's Avatar
HT White Ops
Default Re: stereo install problem
There are only two possibilities:
1) You ****ed up on matching up colors.
2) Your radio is dead.
Old May 20, 2009 | 05:35 AM
New User
it seems like it should be that simple. i know the wires are matched properly, but the likelyhood of the radio failing right out of the box is slim.
thi3v3z's Avatar
there might also be a fuse inside the head unit that blew. Is the head unit brand new??? or did you buy it off some1.also make sure the red wires are solidly connected.
Old May 20, 2009 | 05:36 AM
thi3v3z's Avatar
another thing is dont connect your ground wire to the regular black ground on the pin in the connector. Find a ring connector and find a screw on the frame to connect to. Im thinking your ground is not hooked up properly
Old May 20, 2009 | 05:43 AM
TheCivicMafia's Avatar
Simple way to check
Pull head unit out, Run a power and a ground directly to battery, See if it turns on, if ti does then you either messed up with your wiring or you have a short somewhere in the power...
Also sometimes you have to turn your car on because it may be wired to switched power
New User
yes the unit is brand new store bought. and the ground works with the stock radio. all my connections are soldered and shrink wrapped, no corners cut.
Old May 20, 2009 | 05:46 AM
thi3v3z's Avatar
Then mebbe your head unit is DOA. Take it back and get a new one.
Old May 20, 2009 | 06:33 AM
b18ctrb's Avatar
Did you use a quick connects harness. or one that you have to cut and connect?
Old May 20, 2009 | 10:22 AM
New User
the radio works connected directly to the battery. i need a pic of the stock radio harness pinout. tryed searching with no luck
Old May 20, 2009 | 10:38 AM
thi3v3z's Avatar
we dont know what you drive....
Old May 20, 2009 | 10:44 AM
stevieriot's Avatar
you need to run the ignition power wire to the acc spot on your fuse box. all the other wires are good to hook up to where the stock radio was. the dash does not support enough power to handle an aftermarket radio...
you shoulda blown a fuse when you turned the car on...your parking lights fuse is what woulda blown, so no lights on the dash or your parking lights...
Old May 20, 2009 | 10:50 AM
redlinetuning's Avatar
What brand stereo did you buy? Do you have the red stereo wire going to constant +12v? And is the Yellow stereo wire going to the IGN?
Old May 20, 2009 | 11:00 AM
stevieriot's Avatar
ive installed a lot of stereos. white/blue goes to battery, thats your constant. yellow/red is your ignition. so you will want to connect the new radio's red power wire to your acc on the fuse under your dash. the yellow you will clip onto the white/blue wire...(could aslo be white with yellow, most common white with blue). behind your new stereo every wire will be used except the yellow/red wire, which you should cap off.
hope this helps.
Old May 20, 2009 | 12:03 PM
New User
the harness is connected visa versa red=ign and yellow 12v constant.
Old May 20, 2009 | 12:12 PM
stevieriot's Avatar
use the harness for every wire except the ign power wire. as i stated earlier, you will want that red wire from your new stereo to go to the acc on your indash fusebox. otherwise you will blow a fuse or your lights will be extremely dim
Old May 20, 2009 | 12:15 PM
New User
i will try that next and get back to you later. thanx
Old May 20, 2009 | 01:52 PM
cmcl3m0r3's Avatar
check the harness to make sure that the pins did not back out and are not making connection, this actually happens quite a bit...
-you said radio works fine
-you said factory radio works fine
It HAS to be the harness...or ground
if you want to be safe just check the (yellow) and (red) with a multimeter with the key on and you should get 12v... also check your ground (black)
After reading a few more of the posts I have to edit
Are you hardwiring? (using factory wires with no harness)
Or
Are you using a harness? (aftermarket purchased from store)
BTW EX-MECP Cerftified installer...
Old May 20, 2009 | 01:58 PM
EL Vap133's Avatar
Get that harness from Crutchfield, all you have to do is solder the wires from the harness to the stereo and it will clip onto your stock head unit harness.
Old May 20, 2009 | 02:08 PM
eglude's Avatar
dude just get a freakin test light! hook one side to ground (i would use the one you hooked up to make sure that one is working as well) with the other end touch the yellow one (battery) and see if the light turns on, then touch the red one (IGN) turn the ingition on and see if the light turns on.
Old May 20, 2009 | 02:10 PM
cmcl3m0r3's Avatar
+1^
Also, if you are hardwiring (not recommended) I suggest getting a tone tester to check for your speakers, or you could just use a 9v battery and solder wires to it to make the speakers *pop* to locate correct wires... or get a chart showing what the wires are... I would just get the harness if I were you much easier and less chance of messing something up.
Old May 20, 2009 | 02:18 PM
98civdx's Avatar
Master Detailer
when you all fuese are good are you also saying the fuse on the deck is good?
what type of deck? what kind or car?
also the deck may be dead. it happens alot more then you think.
Old May 20, 2009 | 03:26 PM
CaptWalt's Avatar
Old May 20, 2009 | 05:18 PM
shailoche's Avatar
That's crazy...I simply wired in my harness directly soldering the connections to the stock system and the stereo works fine. I had heard that you had to connect the ground and +12v to a source outside the harness but I didn't have any trouble with mine.
Should work. But maybe your yellow wire, which is fused from the aftermarket company, has blown it's fuse.
stinkypinky1011
Jun 23, 2014 06:13 AM
no_sir
Audio / Security / Video
Nov 6, 2010 03:05 PM
UKej1
Jan 10, 2007 07:00 PM
BIG SHAFE
Jan 24, 2005 07:46 AM
rota426
Jun 18, 2002 04:17 PM
