car shakes a lot and wastes alot of gas?
Old May 19, 2009 | 10:19 PM
EGlove23's Avatar
Icon2 car shakes a lot and wastes alot of gas?
my car shakes alot and it wastes a lot of gas.....i have a d15 non v-tec ingine and it shouldnt waste thet much gas.....anyone help me out!! thanks =D
Old May 19, 2009 | 10:20 PM
geneeunit's Avatar
Default Re: car shakes a lot and wastes alot of gas?
Originally Posted by EGlove23
my car shakes alot and it wastes a lot of gas.....i have a d15 non vtec engine and it shouldn't waste that much gas.....anyone help me out!! thanks =D
what kind of car? original motor? swap? mileage of motor?
do you have a check engine light?
whats your mpg averaging?
Old May 19, 2009 | 10:26 PM
EGlove23's Avatar
ITS A 94 HB EG....AND HAD ORIGINAL MOTOR...THE MILEAGE IS ABOUT 150...NO CHECK INGINE LIGHT.......IDK THE MPG
Old May 19, 2009 | 10:30 PM
geneeunit's Avatar
any broken motor mounts? automatic? manual?
and how do you know its wasting gas if you're not keeping track of the mileage?
also, your driving habits will affect your mileage the most.
Old May 19, 2009 | 10:36 PM
twiztid_989's Avatar
my eg9 does the same thing
Old May 19, 2009 | 10:37 PM
EGlove23's Avatar
ITS MANUAL....NO BROKEN MOTOR MOUNTS.....
I DRIVE A NORMAL AS I CAN....I COULD FULL IT UP WITH GAS...AND USE IT AND THE NEXT DAY ILL HAV 1/4 GONE.....OF MY TANK....IT FEELS LIKE I DONT USE MY CAR AS MUCH TO BE WASTIN DAT MUCH GAS? AND WHY DO U THINK THE SHAKIN?? SOMETIMES IT SHAKES ALOT....SOMETIMES A LITTLE BIT
Old May 20, 2009 | 01:36 AM
waaBAAH's Avatar
CAPS IS THE NEW COOLEST THING HAVNT U HEARD>
OK DIS IZ WHAT U DO
U FIRST CREATE A VERY GUD TITLE GOOD JOB YO
THEN YOU SPELT VTECH WRONG FOO IT VTEC NOT VTECH GET A CLUE
THEN YOU TYPE IN DA CAP METHOD WHAT WRONG YOUR CAP BUTTON BROKE>
WELCOME TO HONDA TECH YO
Old May 20, 2009 | 03:24 AM
Davus's Avatar
Shaking, check alignment. If we don't know your actual mathematical miles driven per 'gallon' or litres used per 100 kilometers, it could just be the stock fuel gauge being inaccurate as always.
Old May 20, 2009 | 05:52 AM
Former User's Avatar
Start by checking/replacing the spark plugs, plug wires, distributor cap, and rotor.
Old May 20, 2009 | 07:05 AM
EGlove23's Avatar
TALKING ABOUT SPELLING? RIGHT....GUD IS REALLY ((.GOOD.))!! AND I TYPE CAPS OR HOWEVER I FEEL LIKE TYPING ;D
Old May 20, 2009 | 07:32 AM
shawn_crx's Avatar
balance your tires....
check for timing issues and a/f ratio's.
Old May 20, 2009 | 08:30 AM
Jimster480's Avatar
caps only is for fgts. this is your first issue. Do you know if its misfiring? do you know how to do math? fill up tank and drive miles. use the fkn odometer. We cant help you with no information. Shakes and uses fuel, ya ok thats so much info rofl. When did u last do oil change? how much do you drive a day? is the car stock? etc.
Old May 20, 2009 | 08:34 AM
Adankid's Avatar
sell it and get yourself a camry. :D
Old May 20, 2009 | 09:15 AM
Jimster480's Avatar
camrys are gay.
Old May 20, 2009 | 01:50 PM
waaBAAH's Avatar
SELL UR CAR AND USE URE VTECH PHONE TO CALL CAB
Old May 20, 2009 | 02:28 PM
xwhitchx's Avatar
well i had this happen to me, it was idleing at a little over 100rpms, (and i dont mean 1000) it was shaking like hell,(timing was good) and my mpgs sucked ***. so i swapped the engine, the took the old one apart.... it had bad rings, and the head was cracked, but thats what happens when you get a d15b2 for $100, id say it was worth the money cuz it lasted 2 months, 3k mils
Old May 20, 2009 | 02:36 PM
chinkstahh's Avatar
i have a 94 eg and i also had the same problem. i found out my engine was running on two cylinders, and had that fixed right away. mechanics told me my engine timing was off which made me burn extra gas.
Old May 20, 2009 | 02:45 PM
1992hondacivicvx's Avatar
does ur car smell like gas ?
Old May 20, 2009 | 03:55 PM
Jimster480's Avatar
how do people not notice things like bad rings or a cracked head or running on 2 pistons? omfg srsly. Blowing smoke and shaking like **** doesnt make lights go off in ur head?
Old May 21, 2009 | 04:00 AM
kojiwafu's Avatar
New User
I had this issue before. just a great thing to put on your carb engine, "enging support" it helps you get no shaking feeling. works 100% also check the timing if its advance or delay, it consumes more gas, its like having a 1.8L engine for a d15 non Vtec engine. :D good luck!
Old Jan 14, 2013 | 02:11 PM
Ryan96GSR's Avatar
I'm going to say this.
I would start by telling us what maintainence you've done to the car already to help us, help you.
Old Jan 14, 2013 | 02:13 PM
Almost 5 year-old thread closed. The OP has probably moved on.
PhantomX
Dec 30, 2005 11:57 AM
LS_teg07
Mar 12, 2004 04:53 AM
flatline
Dec 29, 2003 11:05 PM
Y2Phunk
Oct 22, 2003 10:43 PM
