need help with my 97 lx sedan
build the motor you have
swap in a bigger motor
turbocharge your motor/swapped motor
nitrous
there are many possibilities.... its up to your imagination and budget....
nitrous
I agree. A stock LS swap can be had very cheap and it will run VERY well for the price. If you do an LS swap, you have upgrade options down the road, too. Do LSVTEC with a GSR head (the little extra compression the GSR head yields helps) will make the engine really wake up. Pull the LS trans and sell or trade it for a B16 trans. Stepping stone upgrade system that should let you end up with a low 14-mid 13 second car if you can drive.
mattvivsound
23
Oct 30, 2008 03:51 PM
