building ls/vtec -turbo what to expect
Old May 19, 2009 | 08:48 PM
hatchyboy89's Avatar
Default building ls/vtec -turbo what to expect
hey everybody i am building a ls/vtec turbo motor goin in 91 civic hb dx and i wanna knw what to expect and ur input.. and could i get to 550-650hp anywhere in there...
ok the block
-b18b
-81.5 wisco pistons
-eagle rods
-block gard
-all arp bolts
head
-stock b16a head milled .030
-gsr cams
-adj cam gears
-1000cc inj
-s2 intake mani
-2.5bar map
turbo/mani
-precision SC61 t3/t4 Hybrid .68 4''in 2.5''out
-mini ram horn
-tial 44mm wastegate
-treadstone intercooler 10.5" X 24" X 3.5"
-2.5'' piping
tuning
-turbo edit tuned to 22-25psi
tires
24''x9''x13'' slicks
if i am missing sumthing or u think i should change or need sumthing please put ur input...thanks
and if u guys can share ur setups w/ # and times
Old May 20, 2009 | 05:24 AM
Silva Bullit DC4's Avatar
Default Re: building ls/vtec -turbo what to expect
If you're gonna keep the GSR cams, I would stick with that low end of your power goal (550 whp).
ITR (or Skunk2 Tuner/Pro) cams and bigger turbo (Ex: T3 S366) will get you the 650. And ditch the block guard for GE sleeves. Go with a nice ramhorn or topmount (if the EF clearance issues allow it). I take it the car is for drag only? If so, replace the S2 mani with a Victor X. Otherwise, its a very nice setup, and this is just my nit-picks. ;-)
Old May 20, 2009 | 02:34 PM
drift2004's Avatar
like silva said get bigger cams more power less boost
Old May 20, 2009 | 03:11 PM
yea i want to but i wanna keep the head stock for now cuz i dnt have the $ to do build the head, can i get the Skunk2 wit a stock head and be good? and how much does it cost to sleeve the block and do u guys have web sites or # so i can get ahold of them.
Old May 20, 2009 | 04:48 PM
miguel329's Avatar
http://www.laskeyracing.com/shop/sleeving.htm does good work
Old May 20, 2009 | 05:39 PM
marcj's Avatar
you can expect no traction what so ever
Old May 20, 2009 | 05:45 PM
iwanttokillgod's Avatar
expect to spend money
Old May 20, 2009 | 06:02 PM
If you keep your head stock for the moment, keep your stock rpm so you wont stress out the valvetrain. Forget the Sk2's for now, aftermarket valve springs and retainers are a necessity when running aftermarket cams. Do both later at the same time, if you really stuck on getting Skunk cams.
Old May 20, 2009 | 06:22 PM
ok if i sleeve it what is a good bore, i can keep the 81.50 right...and if i dnt isn't it still can i still meet my goal?
and i knw about trac ill worry about that when that comes....lol
well i am really not set on sk2's but i didnt knw if u can run any kind of cam wit stock head
Old May 20, 2009 | 07:25 PM
redlinetuning's Avatar
if you're going to sleeve it, might as well go 82, 83, or even 84mm pistons. I'm at 81.5 with block guard, no problems.. 14psi right now.. will be pushing 18-20..
Old May 20, 2009 | 07:51 PM
TheShodan's Avatar
Moderator
the 3mm change will not make a significant difference without the accompanying stroke.
Old May 20, 2009 | 09:06 PM
yea i dnt want to get in to stoke it,
and one more thing i have heard it is good to get a girdle?if so what kind is good
Old May 21, 2009 | 07:32 AM
drift2004's Avatar
i just sold my car but i did have a stock sleeve 81.5 bore ran fine i would rev all the way to 9k with no issues although my head was built, i did not have the girdle, all i had was acl bearings, eagle rods and cp pistons and type r oil pump and as far as traction i had plenty compared to other setups @400 wheel power hard to believe but yea 1st no treaction and 2 there is tractions depending on the weather, but if cold i would not get traction at6k-and up on 2nd but 3rd was always fine, i was running the nitto nt01 with 19psi in tire pressure i only drove the car in the weekend though
Old May 30, 2009 | 08:20 PM
and do u guys think i can do this on turbo edit? cuz i dnt wanna covert to obd1
Old Jul 20, 2009 | 12:11 PM
Rease3's Avatar
you can do it but i would convert there is alot more tuning available
Old Jul 20, 2009 | 02:30 PM
turbociv910's Avatar
i ran 11.26 with 445whp in a DA integra with j1 trans, and 25x8x13 tires. Gt35r turbo though.
Lindomar85
Aug 29, 2013 06:29 AM
jdmb16turbo
May 13, 2009 07:00 PM
1lsvtecturbo1
Feb 22, 2009 10:55 AM
Topdawgg
Jul 19, 2006 06:23 PM
Topdawgg
Dec 7, 2005 06:23 AM
