camber question????
k so i have some pretty bad negative camber in the back
and i was gonna put 2 washers under the 2 bolts to push the wheel out so i can get the wheel straight..if i put those washers under the bolts do i need to get longer bolts so the same amount of threads are in the frame? thanks
Depends on the thickness of the washers. But i would recommend getting longer ones regardless and using anti seize because those bolts like to seize themselves
ok thanks guys a couple more questions...is it bad to leave them like that? i know thats a tough question especially since there is no pics...is the only negative thing bad tire wear? and as far as getting longer bolts where should i get them
