Questions About my swap
Old May 19, 2009 | 06:49 PM
JDM EG 117's Avatar
New User
Default Questions About my swap
noob first swap need to know what these are and where they get hooked up or do i need to run wires for them
car is 92 bubble
motor is b16a
Old May 19, 2009 | 07:08 PM
Hanmin's Avatar
Default Re: Questions About my swap
The green one is the knock senser, and I think the pin type one is the oil temp orsomething? If your not throwing any CEL then your alright. Your stock si/ex (assuming) Doesn't use the knock sensor, but I'm pretty sure it uses the oil sensor. and If your running a p28 or , I think jdm b16 ecu, it doesn't look for the knock.
Old May 19, 2009 | 07:14 PM
JDM EG 117's Avatar
New User
im running crank position sensor and cylinder sensor the car starts right up and is fine for 2 mins then runs hard like timing is off thought these might of been part of the problem
RedEj8
Mar 18, 2007 06:29 PM
XzzRzzX
Nov 17, 2005 04:50 PM
LSEGHATCH
Apr 5, 2005 03:07 PM
shadykit
18
Mar 14, 2005 12:51 PM
integranator
Nov 9, 2004 08:16 PM
