3rd brake light FAIL
Old May 19, 2009 | 05:22 PM
jdmwannabee's Avatar
Default 3rd brake light FAIL
car is a 91 acccord dx.
saturday morning all brake lights work fine.
saturday afternoon, 3rd brake light (high brake light) does not work.
things that changed inbetween... i installed an amp + subwoofer and my 50/50 tail lights. i checked all my fuses, even the unrelated ones. they're all good. i used a test light to see if the high brake light was grounding properly and that seems good. i'm getting battery voltage to the high brake light connector, it is a little weak though @ about 10.9 volts. i originally had my amp grounded on the rear deck, but i removed it from there and grounded it under the rear seat. all the other brake lights work.
can anyone help out, i don't want to get pulled over or rear ended.
Old May 19, 2009 | 07:08 PM
Default Re: 3rd brake light FAIL
i've done some digging and found that it could be the brown boxes on the tail lights. can anyone reject or confirm this?
Old May 19, 2009 | 07:19 PM
dohcvtak's Avatar
if there is power to the 3rd brake light lead wire (when u brake) your test light lights up...
and the bulb doesnt light up then check the bulb... if its not the bulb then its the ground assuming that there is power to the 3rd brake light.... stripe a little off the top of the ground add a wire and touch it to chassis and have some one step on the brake..
Old May 20, 2009 | 04:37 AM
the ground is good, and it's getting power. i'm beginning to think it's the stop light failure sensor. i guess it malfunctioned or something. part #28/29 in the illustration. i'll mess with it today and see if anything happens. anybody else have any suggestions.
Old May 22, 2009 | 09:40 PM
masterkill455's Avatar
ummm, if your light has power and ground but doesnt light your bulb is blown
Old May 23, 2009 | 08:09 AM
i believe i have a bad light socket, so i'm going to swap it out and see what happens.
Old May 27, 2009 | 05:30 PM
im telling you, the bulb is bad if you have power and ground and the bulb doesnt light up, take an ohms reading on the bulb, your meter will read infinity or OL, no circuit
Old May 27, 2009 | 07:53 PM
notAdiesel's Avatar
maybe something is getting messed up with the different brake lights
but the simplest thing would be to swap a bulb, i think all the brake lights and reverse lights use the same ones
studlete
Sep 4, 2009 07:39 PM
AndyD
Feb 18, 2008 11:09 PM
EASY101
Jul 10, 2006 02:26 PM
luvmyhonda
Aug 21, 2004 03:35 PM
D-Day
May 23, 2001 06:31 PM
