b16 in del sol not wanting to get into gear
Old May 19, 2009 | 02:22 PM
killahatch's Avatar
Default b16 in del sol not wanting to get into gear
hey guys my friend has a 94 civic del sol with the stock b16a3. well recently it would not get into gear, if it did it would be really hard or would grind. im thinking its either the clutch or master cylinder. any ideas would be greatly appreciated. if you pump the clutch it would work for about 5 minutes then the symptons would return.
Old May 19, 2009 | 04:14 PM
iamthefollower's Avatar
Default Re: b16 in del sol not wanting to get into gear
check the slave cylinder too, but more than likely it is the master cylinder as you have already stated..
Old May 19, 2009 | 07:26 PM
killahatch's Avatar
if it were the clutch wat would be some symptons i would be seeing? btw idk if i metioned it but we bled the clutch and it didnt seem to do much. im at a lose guys any other ideas?
thanks.
Old May 19, 2009 | 07:34 PM
Brandon H.'s Avatar
I owned a Izuzu Rodeo that had the same problems. It would not go into gear, it had to be forced and sometimes it would grind the gears. I had to pump the clutch to make the clutch work, and that only lasted about a minute.
The problem.... slave cylinder. You might want to look into that.
Old May 19, 2009 | 07:38 PM
Rok_Stok's Avatar
Grinding into gear, or not going into gear at all can also be caused by worn out synchronizers assemblies in the transmission. Afterall, they're only made of brass, this is so they'll wear first, and not the more expensive hardened steel parts like input shaft and countershaft gears.
Derek Malone
Transmission & Drivetrain
Apr 24, 2019 03:16 PM
sol817
13
Jul 20, 2015 05:00 PM
Jason P
17
Feb 1, 2008 09:14 PM
PatrickGSR94
17
Aug 3, 2006 08:36 PM
hondadelsol.co.uk
Jul 26, 2004 10:19 AM
