Shifter movement
Old May 19, 2009 | 10:43 AM
jpvipond's Avatar
Default Shifter movement
Hi All,
I have a 97 civic ex with 141,000 miles. When I accelerate I can see the shifter move and when I go over large bumps (considering I live in PA this occurs frequently) the shifter has a lot of movement. Also I can feel engine vibration when holding the shifter. I was wondering what the cause of this problem would be. My guess is the front engine mount.. But I was also wondering if it could be the bushings for the shifter. Any help would be much appreciated. Thanks
Old May 19, 2009 | 10:47 AM
Former User's Avatar
Default Re: Shifter movement
Check the rear mount.
Old May 19, 2009 | 11:29 AM
jpvipond's Avatar
I also forgot to mention that when I accelerate (in any gear) the shifter movement is always backward toward the e-brake and never forward movement.. i don't know if this changes your diagnosis or not but I thought every bit of info would be helpful... What is the best way to check the mounts to determine whether they need replacement.. Thanks for the help
Old May 19, 2009 | 11:44 AM
Originally Posted by jpvipond
...What is the best way to check the mounts to determine whether they need replacement.
Check whether it is loose, damaged, or the rubber is cracked or degraded.
Old May 19, 2009 | 06:59 PM
jpvipond's Avatar
Found the problem it was the front top driver side engine mount... Thanks for the help
Ryan96GSR
Mar 12, 2012 02:26 PM
dRoPpEd lS
Mar 9, 2009 09:02 PM
eternalboy
Feb 11, 2007 08:57 PM
CTR-GSR
Feb 24, 2006 09:47 PM
rasta420
Nov 25, 2004 09:57 PM
